My Turbo LSX Z31 Build.
#64
Dropped the heads of at the machine shop it have them cleaned & resurfaced. Also had the valve covers, oil pan, & timing cover media blasted. I also replaced the cam bearings. While I was doing this I figured "Why not step my engine bay game up?". I chose to shave the stand offs & weld -10an fittings on my valve covers.
Cylinder Heads Before
![Name: 20160111_000339.jpg
Size: 161.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602949d1501281909-my-turbo-lsx-z31-build-20160111_000339.jpg)
![Name: 20160111_000432.jpg
Size: 131.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602950d1501281909-my-turbo-lsx-z31-build-20160111_000432.jpg)
![Name: 20160111_000441.jpg
Size: 145.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602951d1501281909-my-turbo-lsx-z31-build-20160111_000441.jpg)
![Name: 20160111_000454.jpg
Size: 157.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602952d1501281909-my-turbo-lsx-z31-build-20160111_000454.jpg)
![Name: 20160111_000526.jpg
Size: 127.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602953d1501281909-my-turbo-lsx-z31-build-20160111_000526.jpg)
Cylinder Heads After
![Name: 20160113_181916.jpg
Size: 135.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602954d1501281909-my-turbo-lsx-z31-build-20160113_181916.jpg)
![Name: 20160113_181933.jpg
Size: 191.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602955d1501281909-my-turbo-lsx-z31-build-20160113_181933.jpg)
![Name: 20160113_181945.jpg
Size: 218.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602956d1501281909-my-turbo-lsx-z31-build-20160113_181945.jpg)
![Name: 20160113_182004.jpg
Size: 204.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602957d1501281909-my-turbo-lsx-z31-build-20160113_182004.jpg)
![Name: 20160113_181954.jpg
Size: 199.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602958d1501281909-my-turbo-lsx-z31-build-20160113_181954.jpg)
#68
Purchased all these goodies for the 4.8
LJMS Stage 1 4.8 Turbo Cam
BTR 660 Dual Valve Springs with Titanium Retainers
Comp 7.400 Hardened Push Rods
Straub Technologies Trunnion Kit
ARP Head Studs
ARP Stainless Steel Valve Cover Bolts
ARP Stainless Steel Water Pump Bolts
ARP Stainless Steel Intake Manifold Bolts
ARP Stainless Steel Oil Pan Bolts
ARP Stainless Steel Timing Cover Bolts
ARP Balancer Bolt
ARP Camshaft Bolts
Summit 25% Underdrive Balancer
Improved Racing Oil Pan Baffle
Meling 10295 High Oil Pressure Pump
Hinson Racing C7R Timing Chain
Billet EGR block Off Plate
LS7 Lifters
New Lifter Trays
GM Performance 12498544 Head Gasket
Dorman Drain Plug 65221(Deletes oil level sensor)
New GM 12589016 Camshaft Retainer
New Oil & Coolant Plugs
New Cylinder Head Dowels
Dorman 635-518 Rear Main Seal Cover Set
New Gaskets for the entire engine
MS3 Gold Box
Siemens Deka 80 LB/HR Fuel Injectors
3 Bar Map sensor
Fast Fuel Rails(Scored these for 50$)
12.9 grade Rocker Arm Bolts
![Name: 20160215_101319.jpg
Size: 168.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602911d1501281840-my-turbo-lsx-z31-build-20160215_101319.jpg)
![Name: 20160215_095332.jpg
Size: 79.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602912d1501281840-my-turbo-lsx-z31-build-20160215_095332.jpg)
![Name: 20160215_095346.jpg
Size: 463.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602913d1501281840-my-turbo-lsx-z31-build-20160215_095346.jpg)
![Name: 20160215_095511.jpg
Size: 157.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602914d1501281840-my-turbo-lsx-z31-build-20160215_095511.jpg)
![Name: 20160215_095607.jpg
Size: 106.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602915d1501281840-my-turbo-lsx-z31-build-20160215_095607.jpg)
![Name: 20160215_095615.jpg
Size: 95.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602916d1501281840-my-turbo-lsx-z31-build-20160215_095615.jpg)
![Name: 20160215_095708.jpg
Size: 125.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602917d1501281840-my-turbo-lsx-z31-build-20160215_095708.jpg)
![Name: 20160215_095739.jpg
Size: 91.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602918d1501281840-my-turbo-lsx-z31-build-20160215_095739.jpg)
ARP Head Studs
ARP Balancer Bolt
ARP Camshaft Bolts
LS7 Lifters
New Lifter Trays
MS3 Gold Box
3 Bar Map sensor
![Name: 20160215_095817.jpg
Size: 97.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602919d1501281840-my-turbo-lsx-z31-build-20160215_095817.jpg)
#71
Now that I have my assortment of parts it was time for assembly.
1st I cleaned & began to lap all the valves. After lapping a few I found a couple pits on the seat of the valve. So I decided to get valve job.
![Name: 20160512_170737.jpg
Size: 132.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602880d1501281840-my-turbo-lsx-z31-build-20160512_170737.jpg)
![Name: 20160516_140826.jpg
Size: 168.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602881d1501281840-my-turbo-lsx-z31-build-20160516_140826.jpg)
![Name: 20160516_140950.jpg
Size: 161.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602882d1501281840-my-turbo-lsx-z31-build-20160516_140950.jpg)
![Name: 20160516_141002.jpg
Size: 148.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602883d1501281840-my-turbo-lsx-z31-build-20160516_141002.jpg)
After that I installed the valves & Premium BTR 660 valve spring kit. Then set the cylinder heads off to the side.
![Name: 20160516_151449.jpg
Size: 177.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602884d1501281840-my-turbo-lsx-z31-build-20160516_151449.jpg)
![Name: 20160516_151633.jpg
Size: 198.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602885d1501281840-my-turbo-lsx-z31-build-20160516_151633.jpg)
![Name: 20160516_151711.jpg
Size: 190.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602886d1501281840-my-turbo-lsx-z31-build-20160516_151711.jpg)
![Name: 20160516_151813.jpg
Size: 176.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602887d1501281840-my-turbo-lsx-z31-build-20160516_151813.jpg)
![Name: 20160516_152653.jpg
Size: 180.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602888d1501281840-my-turbo-lsx-z31-build-20160516_152653.jpg)
![Name: 20160516_155328.jpg
Size: 183.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602889d1501281840-my-turbo-lsx-z31-build-20160516_155328.jpg)
![Name: 20160516_155409.jpg
Size: 267.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602890d1501281840-my-turbo-lsx-z31-build-20160516_155409.jpg)
#75
Installed cylinder head dowels. Lightly lubed the threaded sections of the ARP Head Stud with ARP lube. Then threaded them into the block hand tight.
![Name: 20160516_164145.jpg
Size: 174.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602836d1501281759-my-turbo-lsx-z31-build-20160516_164145.jpg)
After that I coated my head gaskets with copper spray & slid them over the studs.
![Name: 20160516_165750.jpg
Size: 228.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602837d1501281759-my-turbo-lsx-z31-build-20160516_165750.jpg)
![Name: 20160516_172841.jpg
Size: 235.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602838d1501281759-my-turbo-lsx-z31-build-20160516_172841.jpg)
Carefully lowered the cylinder heads down over the head studs.
![Name: 20160516_170144.jpg
Size: 227.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602839d1501281759-my-turbo-lsx-z31-build-20160516_170144.jpg)
After that I lightly applied ARP lube to the washer & threads of the nuts. Then I installed the washers & threaded the nuts down hand tight. Following GM's recommended torque sequence I tightened the 7/16" nuts in 3 equal steps to 80 ft lbs. The 5/16" nuts were torqued to 25 ft lbs.
![Name: 20160516_172304.jpg
Size: 235.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602840d1501281759-my-turbo-lsx-z31-build-20160516_172304.jpg)
![Name: 20160516_174854.jpg
Size: 237.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602841d1501281759-my-turbo-lsx-z31-build-20160516_174854.jpg)
Continuing on I tossed in my pushrods & set the rockers in their respected places. With the engine in the number one firing position, I tightened exhaust valve rocker arm bolts 1, 2, 7, and 8 to 22 ft lbs. Then I tightened intake valve rocker arm bolts 1, 3, 4, and 5 to 22 ft lbs.
I rotated the crankshaft 360° & tightened exhaust valve rocker arm bolts 3, 4, 5, and 6 to 22 ft lbs. Last but not least I tightened intake valve rocker arm bolts 2, 6, 7, and 8 to 22 ft lbs.
![Name: 20160516_204521.jpg
Size: 236.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602842d1501281759-my-turbo-lsx-z31-build-20160516_204521.jpg)
![Name: 20160516_204527.jpg
Size: 242.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602843d1501281759-my-turbo-lsx-z31-build-20160516_204527.jpg)
![Name: 20160516_205426.jpg
Size: 246.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602844d1501281759-my-turbo-lsx-z31-build-20160516_205426.jpg)
![Name: 20160516_205436.jpg
Size: 233.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602845d1501281759-my-turbo-lsx-z31-build-20160516_205436.jpg)
![Name: 20160516_205443.jpg
Size: 227.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602846d1501281759-my-turbo-lsx-z31-build-20160516_205443.jpg)
![Name: 20160516_205452.jpg
Size: 244.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602847d1501281759-my-turbo-lsx-z31-build-20160516_205452.jpg)
#76
After a few rotations I double checked all the rocker arm bolts with my torque wrench. Now that made sure I had no binding issues it was time to install my valve covers & Meling oil pump. I installed the Meling oil pump following their directions. Using 3 .0025 feeler gauges equally spaced between each rotor. Plus 3 more equally spaced .0025 feeler gauges between the largest rotor & pump casing. Then torqued the pump bolts to 18 ft lbs. Then secured pump cover using supplied bolts with a bit Loctite 242.
![Name: 20160516_122601.jpg
Size: 213.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602827d1501281759-my-turbo-lsx-z31-build-20160516_122601.jpg)
![Name: 20160516_122720.jpg
Size: 216.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602828d1501281759-my-turbo-lsx-z31-build-20160516_122720.jpg)
![Name: 20160516_123228.jpg
Size: 234.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602829d1501281759-my-turbo-lsx-z31-build-20160516_123228.jpg)
![Name: 20160516_123550.jpg
Size: 218.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602831d1501281759-my-turbo-lsx-z31-build-20160516_123550.jpg)
![Name: 20160516_215926.jpg
Size: 207.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602832d1501281759-my-turbo-lsx-z31-build-20160516_215926.jpg)
![Name: 20160516_221317.jpg
Size: 215.1 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602833d1501281759-my-turbo-lsx-z31-build-20160516_221317.jpg)
![Name: 20160516_220621.jpg
Size: 226.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602834d1501281759-my-turbo-lsx-z31-build-20160516_220621.jpg)
![Name: 20160516_221324.jpg
Size: 204.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602835d1501281759-my-turbo-lsx-z31-build-20160516_221324.jpg)
#77
Next I installed my timing & rear main seal covers using some Alignit tools. These things come in handy. After the covers were aligned I installed the seals.
![Name: 20160516_213640.jpg
Size: 221.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602815d1501281759-my-turbo-lsx-z31-build-20160516_213640.jpg)
![Name: 20160516_213934.jpg
Size: 222.2 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602816d1501281759-my-turbo-lsx-z31-build-20160516_213934.jpg)
![Name: 20160516_232753.jpg
Size: 220.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602817d1501281759-my-turbo-lsx-z31-build-20160516_232753.jpg)
![Name: 20160516_233350.jpg
Size: 212.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602818d1501281759-my-turbo-lsx-z31-build-20160516_233350.jpg)
Moving on I installed the Improved Racing oil pan baffle into my F-Body oil pan. It's a shame that something so nice won't be seen.
![Name: 20160517_001053.jpg
Size: 138.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602819d1501281759-my-turbo-lsx-z31-build-20160517_001053.jpg)
![Name: 20160517_001128.jpg
Size: 169.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602820d1501281759-my-turbo-lsx-z31-build-20160517_001128.jpg)
I also deleted my oil level sensor but using Dorman Drain Plug 65221.
![Name: 20160517_000012.jpg
Size: 133.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602821d1501281759-my-turbo-lsx-z31-build-20160517_000012.jpg)
![Name: 20160517_000016.jpg
Size: 173.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602822d1501281759-my-turbo-lsx-z31-build-20160517_000016.jpg)
The balancer started looking lonely on my work bench so I slapped it on followed by the ARP Balancer Bolt.
![Name: 20160516_214449.jpg
Size: 215.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602823d1501281759-my-turbo-lsx-z31-build-20160516_214449.jpg)
![Name: 20160516_214950.jpg
Size: 210.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602824d1501281759-my-turbo-lsx-z31-build-20160516_214950.jpg)
![Name: 20160516_215537.jpg
Size: 211.6 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602825d1501281759-my-turbo-lsx-z31-build-20160516_215537.jpg)
![Name: 20160516_215545.jpg
Size: 215.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602826d1501281759-my-turbo-lsx-z31-build-20160516_215545.jpg)
#80
To finish up the 4.8 I installed the water pump & valley cover.
![Name: 20160517_012421.jpg
Size: 214.4 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602797d1501281695-my-turbo-lsx-z31-build-20160517_012421.jpg)
![Name: 20160518_205150.jpg
Size: 112.5 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602798d1501281695-my-turbo-lsx-z31-build-20160518_205150.jpg)
![Name: 20160518_210220.jpg
Size: 215.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602799d1501281695-my-turbo-lsx-z31-build-20160518_210220.jpg)
With the 4.8 together I needed to find a clutch. I originally ordered clutch but they requested I buy their flywheel. Which informed that would be useless for me. Well that struck a cord with them. So I explained my setup & they told me the LS wouldn't even fit in car. I told them to Google my car which must be mystical unicorn ROFL. Got my refund and began searching for another option. Found a couple options. In 1 hand there was an affordable 700-800$ clutch. In the other there was a 2100$ clutch that was way more than I needed. The 1st clutch appeared to fit my needs & had a nice price to match. So I gave the clutch maker a call. They informed me that my set up would be pushing to the limits of that clutch. They've had people make 800+hp but on less torque producing V6's. Not wanting to be held back by my clutch I went with option 2. It hurt in the beginning. Hell this clutch cost more than my car, turbo, engine & transmission combined lol. But it'll aid me obtain my goals & pay for itself in the long run. Due to the fact it's a twin disc & can be rebuilt. I went with Ceramic & Rigid Organic disc combination per Clutch Masters recommendation. The clutch comes with a custom flywheel that allows you to back the LSX with a Z32 transmission. With that said they're made to order. I was quoted 3-4 weeks for them to make it. I figured it was likely another week for shipping. Boy was I wrong. My clutch was delivered in just 10 days!
While I was waiting on my clutch I went ahead & had my starter rebuilt.
![Name: 20160205_101255.jpg
Size: 123.8 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602800d1501281695-my-turbo-lsx-z31-build-20160205_101255.jpg)
![Name: 20160205_101308.jpg
Size: 121.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602801d1501281695-my-turbo-lsx-z31-build-20160205_101308.jpg)
![Name: 20160525_120134.jpg
Size: 109.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602802d1501281695-my-turbo-lsx-z31-build-20160525_120134.jpg)
![Name: 20160525_120248.jpg
Size: 108.3 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602803d1501281695-my-turbo-lsx-z31-build-20160525_120248.jpg)
I also converted my power steering rack to manual. Here's how the rack started out.
![Name: 20160513_184813.jpg
Size: 261.7 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602804d1501281695-my-turbo-lsx-z31-build-20160513_184813.jpg)
After I hit it with some glass bead media
![Name: 20160515_205339.jpg
Size: 115.9 KB](https://ls1tech.com/forums/attachments/conversions-swaps/602805d1501281695-my-turbo-lsx-z31-build-20160515_205339.jpg)
