lost... battery/alternator wiring
Some background, car is a 93 rx7 with a 2001 z28 ls1 it had a hacked harness for the swap. i have a new standalone harness that i just put in few weeks ago. Right now I have battery+ -> starter -> alternator
There is 2 large 6 gauge coming off the alternator, one is cut so i capped it for now. Other went to the frame. I noticed that one going to the frame was scorching hot after having the battery connected for about 30seconds tops. ive disconnected that but been trying to troubleshoot since.
I used my multimeter ohm function to test continuity between positive and negative cables and i get no tone no reading? im a bit lost on this part of the wiring. any help would be great!
https://ls1tech.com/forums/generatio...g-threads.html
as of now, no. ends at the alternator currently. nothing is coming back to the positive side of the battery. there is just the "crossover" from starter to alternator.
Curious: Why would this cable be grounded to the frame?
Got any pics?
So the battery main + cable is going to the starter, from the starter to the alternator(what I'm calling the crossover) there it ends. There is however a cut red wire there that I capped. Another black wire was coming off the back of the alternator also, and bolted to the engine bay. In these pictures I have it cut.
So - battery----starter----alternator. I called the company that did my engine harness and said "it should be grounded" when I asked. Asked about the other wire and said to "try a couple things out" haha, I think I called during lunch break.
Thanks for all the help btw
Unrelated, I'm using a leash electronics board for my chassis harness and that thing seems to be DOA... Been a good day.
Glad you got this fixed. Now onto I'm sure your many other problems!
