530ZX - In progress
Old Jan 28, 2016 | 01:48 PM
  #41
blackened's Avatar
Careful with the F-body pan and high volume oil pumps. Mine would uncover the pickup under hard acceleration. Went with an improved racing baffle kit for the F-body pan to fix it.
Yeah my thinking was that I'd use the extra volume to maintain flow rate when using an oil cooler due to the extra line? Admittedly, I'm a noob, so someone will need to chime in if this an incorrect approach?
Old Jan 28, 2016 | 03:04 PM
  #42
Forcefed86's Avatar
The Fbody pan will still allow the oil to slosh back and uncover the pickup. It's worse with the high volume pumps because they run the pan at a lower oil level than the standard volume pumps. I tried adding additional oil as a crutch and it worked ok with a factory oil pump. The high volume pump sucked the oil level down too far no matter what I did. I had 7.5qts in my 5.5qt fbody pan and still lost oil pressure on acceleration. You need baffles or you need to move the pickup to the back of the pan IMO.
Old Jan 28, 2016 | 10:02 PM
  #43
blackened's Avatar
Thanks for the information sir
Old Jan 29, 2016 | 10:04 AM
  #44
DW SD's Avatar
The Holley 302-2 is knock off (more or less) from the F-body pan. It looks like it is a rear pickup from pictures online (I can't remember where the pickup is, even though I installed it only a year ago or less).
I have the L92 with VVT and thus high volume pump. Anyone know if the issue exists with Holley's pan, too? I've never seen low pressure upon WOT, but I don't stare at the gauge, nor do I have an idiot light for oil pressure. (will the PCM trigger a check engine light??) I don't get one of those.
I don't drag race, either, but do get on WOT frequently.
Doug
Old Jan 29, 2016 | 03:19 PM
  #45
FlatBlack's Avatar
Originally Posted by blackened
Thanks man! I'm planning on running a S14 rear sub frame to benefit from the improved anti-squat over the S13 and also to maintain the 5 lug hubs, but really wanted to run the Z32TT diff/axles because of the thicker axles and larger diff. So how much did you have to mod the sub frame to fit it in the S13 sub frame?
I just need to buy some S13>S14 Conversion bushings and it bolts up (I Haven't done it yet)
http://www.splparts.com/spl-pro-soli...-bushings-s13/
Old Jan 30, 2016 | 06:58 AM
  #46
AAIIIC's Avatar
The oil cooler circuit is in series with the rest of the oiling system, so you don't need a high volume to account for that, you just need to ensure you fill the system with extra oil to account for the larger system. You can probably find the capacity of the oil cooler itself on the manufacturer's website, or just fill the thing yourself to see how much oil it holds. Then add the capacity of the lines (based on the internal diameter x length of hose used).
You could maybe use a higher pressure oil pump, but really as long as you use appropriately sized plumbing (at least -10 with full-flow fittings) there should be minimal pressure drop through the oil cooler.
Old Jan 30, 2016 | 11:51 AM
  #47
BLKMGK's Avatar
I'd be Leary of the R230 diff from the ZXTT, posted elsewhere as to why but strength, gear availability, and the case being too small to fit larger gears about sums it up.
Old Jan 31, 2016 | 10:22 PM
  #48
blackened's Avatar
yes sir, I have get those and the swap kit ASCO sells
I went back and confirmed I bought the 10295 which is the high pressure pump, not the high volume. I do plan on running an oil cooler, but if the pressure drop isn't substantial, then i'd suppose I don't need it, but if i leave it in there, are there any concerns I should know about?
S14 R200 it is then!
Old Feb 1, 2016 | 11:18 PM
  #49
Jay Gadsby's Avatar
Srength is not the issue, limited gearing is. 3.69 in TT 300zx trim, a d a couple others in Armada trim, but very few have turned the Armada diff into an LSD and documented it. The R200 when properly built will do just fine for most applications, but do not discount the R230 as weak. Plenty of Z guys running lots of power through them for many years now. Just too few choices for gearing.
Old Feb 2, 2016 | 11:22 AM
  #50
ryeguy2006a's Avatar
Awesome project and nice work.
Old Feb 2, 2016 | 09:28 PM
  #51
blackened's Avatar
I'll proceed with the R200 and if need be i can always switch to a R230 or something else if/when the need arises.
Thank you sir, the interior cleanup, patching, and painting is progressing slowly currently
Old Feb 2, 2016 | 10:53 PM
  #52
BLKMGK's Avatar
R230 gears are plenty stout but the stub shafts shear and last. Looked there was nothing available stronger. The R200 is likely weaker, you'll want good shafts for sure and you will also have gearing issues I'm betting as most of the cars that use them have smaller displacement engines that spin higher - 1st in a T56 will be quite short. BTDT! I've got a viscous R200 with CVs in my 240Z with a kit to swap in an 8.8 in a box.
Old Feb 8, 2016 | 09:36 PM
  #53
blackened's Avatar
Stock brake booster and Wilwood CMC came in. Primed and painted in wrinkle black
Rigid Racing CMC adapter and Z32 1" BMC
Finished up the sound deadening removal in the rear and found some Doublemint
Old Feb 9, 2016 | 10:12 PM
  #54
blackened's Avatar
Primed and painted the BMC
Got the radiator (3 core Champion) in tonight and got it installed. Had to make a small notch to accommodate the drain
Old Feb 9, 2016 | 10:47 PM
  #55
DirtyBird2000's Avatar
Wow man, this is some quality work. Cant wait to see it when its finished.
Old Feb 26, 2016 | 09:44 PM
  #56
blackened's Avatar
Thanks man, its been taking a lot of patience!
Old Feb 26, 2016 | 10:07 PM
  #57
blackened's Avatar
Z31 brake booster and the Z32 1" BMC
The last few weeks have been all about cooling and power steering in an effort to get everything underhood completed.
Main shipment of power steering parts
More presents
Ended up going another route and will not be using the coolant inline filler pictured
Plug! Please subscribe on YouTube
Making the PS pressure line with -6AN PTFE
Removing the barbs on the water pump
Derale Fan/shroud came in. Fit and finish are excellent.
Pleasantly surprised to find that the fans are SPAL. 2000 cfm each
Going to have to drop the rad down an inch or so to accommodate the thickness of both the rad and fan shroud
Ebay fuel pressure gauge started leaking oil already, so it will be replaced with this Aeromotive one
Majority of the last shipment came in today. Waiting on the Canton surge tank, swivel tstat housing and oddball fitting for the tank
Not 530ZX, but also had my Doug Rippie revalved Bilsteins come in today for the C6Z
Old Mar 4, 2016 | 12:34 AM
  #58
blackened's Avatar
Made some drop mounts out of aluminum tube, rubber well nuts with 10-24 threaded inserts, ss all thread, and ss hardware. Not that it matters, but i didn't have to modify the car at all with these.
First cooling line mock up
Swivel Tstat housing and Canton surge tank came in
Final coolant mockup to determine gaps
Swapping bottom coupler to a 45
Straight 1/2" NPT to 5/8" isn't going to clear. Will order a 90 degree
Clears the hood...barely
Plenty of room for a turbo
Bam! Picked up a T56 locally out of a LS1 Fbody
Old Mar 4, 2016 | 11:01 AM
  #59
Project GatTagO's Avatar
Nice score on the F-body T56. Those are getting hard to find!
Andrew
Old Mar 11, 2016 | 09:00 AM
  #60
Nismo Kid's Avatar
The project is coming along nicely.
