LS1 rear end in third gen?
Other than gaining the big disc brakes, and having lower miles, I don't see much advantage.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Clint
www.speartech.com
Our 10-bolt is holding up fine in our '01 z, It is a 4L60e with a Yank TP4400 with a stock 10-bolt and 4.10 gears, no reinforement at all. stock cover, stock housing, stock style crush sleeve stc. And it is holding up to 1.47 60's and high 10's 1/4 all day long. But i do believe we are getting a little lucky, but how extreme are these third gens going to get. They can take some abuse though.
Clint
Clint
My only point was that as you start pouring the power to a 3rd gen, a 4th gen rear end should not be considered a real strength upgrade.
The guy above who said they are "tons better" only made a big improvement over his original, apparently crummy setup. He must have had a single pull, high ratio, drum brake rear in his 3rd gen, so he was able to make a big improvement by going to a 4th gen rear with posi, better gear ratio, and disc brakes.
As a general rule for a similarly optioned rear end, the late 4th gen offers bigger brakes, maybe a slightly stronger posi, and that's about all.
www.speartech.com
The guy probably launches harder on traffic lights than most of us do at the strip.
Clint
