Compression fittings to 6an ?
Will these fittings work on my SS 3/8" hard fuel feed line. I need something to connect my -6an soft lines to the tank sending unit and the fuel rails. I'm using an in tank pump, vett FFR in an 07 LS2.
I guess my question is do they hold up to the fuel pressure over the course of time or do I have to bite the bullet and by a 37 degree flaring tool for just two flares.
http://www.ebay.com/itm/330670984578?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks, Tony
Thanks, Tony
I have Swageloc compression fittings on my power steering line and on my fuel line. They are rated well above 1500 psi. Not Cheep but work well. Didn't look at your location but if your anywhere near Tampa I have a 37 flare you can use as well.
Thanks you guys, Russ I did order from your Link, the had every thing in stainless which is what I had been looking for. I also found a cheap 37 degree flaring tool on ebay that I will test on some scrap tubing.
But I gotta say that if someone had told me that I would be spending a grand on a fuel system, and that's with using a B body tank, I would have bought one of those ZZ whatever crate motors and called this done.
Thanks, Tony
Thanks, Tony
Tony,
IF you would of settled for a ZZx crate motor, you would of regretted it later on. LS power !!!!!!
Yes it will work fine and is rated to hundreds of pounds of pressure , IF, it has a metal collar that collapses on the line , if its a rubber sleeve , it is only rated to 3 bar , or around 45 pounds
37deg flares are pretty easy. If your cheap flare tool doesn't work, I'm about 25min away around the Beltway, and have a nice Imperial Rol-Air flare tool you could borrow.
Pre 730623E 6 An Male to 3 8" Tube Hardline Fuel Line Adapter Nickel Aluminum | eBay
Thanks, Tony
Thanks, Tony
Russ Kemp
These will do what you want and take the pressure. Check with your local hydraulic shop, they may stock them...
Thanks again
As S10xGN said...get to know your local hydraulic guy...I have a Parker Hydraulic store near me and I made friends with a really good parts man there...he makes the power steering and fuel system fab a lot less painful on all my swaps...
(And yes, my fuel system cost me about double my original estimate)
