Anyone running manual heater core bypass valve ??
Thinking of doing a manual valve setup on my car. I recently changed my giant foxbody hvac system and installed a small stand alone heater. Now this heater is simple it's either going to run or be totally turned off including the coolant. I was looking into the factory setups (explorer and f body) but they all run off vacuum and I don't need that. Can any of the vacuum setups be manually set? Do they recirculate or just block the heater core ? I was also thinking just get a T fitting and some valves and valve off the heater core when not in use and open the circulation tube. Any help or ideas I'd appreciate.
Old air products. They make a cable pull bypass valve that works.
http://www.oldairproducts.com/catalo...sort=3a&page=2
Yes exactly what I'm looking for thanks
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/1500x2000/image_a3301d54bdf550939caec4695289ce76b9592524.jpg)
Like this u could prob convert to manual
