water pump info Ls1
water pump info Ls1
Converted a LS1 into my 1941 chev pick up is there a water pump available that I can run a clutch fan or fixed fan for cooling as I don't want to run electric fan if possible
Not on a true LS1, but if you want to switch to the front accessories off of a truck you can. The truck stuff is a little further out than the f body stuff though. Im not sure you could get any kind of air cleaner on an LS1 with a fan on the water pump because the throttle body is going to be too far forward.
Hi garys 68
I'm located in Australia and the LS1 came out of a Commodore sedan 2002 model so not sure on spacings out of my depth a little so chasing as much info as I can find thanks in advance
