Saturn LS4 Swap Sleeper Project
Old Nov 3, 2016 | 07:06 PM
  #61
Sean R's Avatar
Here's a little video of it driving on some back roads
Old Nov 9, 2016 | 08:53 PM
  #62
Sean R's Avatar
So I some exhaust work. I added a crossover pipe between the true duals just to see what the difference would be.
Here's a video comparing them.
Old Nov 10, 2016 | 07:25 PM
  #63
70 Bug Mid Engine's Avatar
If you need some more axles with CVs, just let me know. I still have the 2 I used for mock up on the Bug. One is still pretty long but the other one probably has about an 8" shaft left.
But glad to see it was up and running and driving!
Old Nov 12, 2016 | 03:24 AM
  #64
White Out's Avatar
This is amazing. Great work!
Old Nov 14, 2016 | 12:31 PM
  #65
BudRacing's Avatar
This thing would make a great daily driver once you get the driveline sorted for strength.
How much does this thing weigh now?
Old Dec 2, 2016 | 12:40 PM
  #66
Narxoleptic's Avatar
What a great build! that exhaust is a little telling though....but with the way it looks I'm sure folks just think the exhaust is rotted thru. In for more videos!!
Old Dec 2, 2016 | 02:42 PM
  #67
Sean R's Avatar
Thanks!
I'd estimate its around 2500 lb
Old Dec 5, 2016 | 10:57 AM
  #68
ryeguy2006a's Avatar
More details on the Turbo LS RSX?
Old Dec 5, 2016 | 11:11 AM
  #69
BudRacing's Avatar
//edit repost//
Old Dec 5, 2016 | 03:00 PM
  #70
Sean R's Avatar
It's a pretty similar setup to mine, but with ARP hardware and an AiReseach turbski with a fist sized compressor inlet and a water to air intercooler. Oh and a couple hundred more bald eagles under the hood. It should be running around this spring.
Old Jan 4, 2017 | 05:08 AM
  #71
Sl2 800hp's Avatar
Default Transmission
What trans did you use
Old Jan 4, 2017 | 01:11 PM
  #72
Centerforce's Avatar
If we read correctly, the stock saturn 5-spd bolted right up without an adapter.
Old Jan 6, 2017 | 09:52 AM
  #73
Sean R's Avatar
Used a GM Getrag manual transmission with a 60 degree bellhousing pattern. It appears that most of them do hold the power. I'd prefer not to say exactly which one I am using, since I don't want to give people a false idea that the trans I am using is "bulletproof".
Old Jan 7, 2017 | 01:42 PM
  #74
Sl2 800hp's Avatar
I was wondering cause my Saturn is the 94 model the boxy looking one
Old Nov 6, 2017 | 11:51 PM
  #75
Tautcord0887's Avatar
Cool How much
If I where to pay would u do mine
Old Jan 11, 2018 | 12:47 AM
  #76
Darrian Goree's Avatar
Was tryna figure out a way to make my 06 SS Monte Carlo faster now I have a way
Old Apr 17, 2018 | 03:00 PM
  #77
bgordon86's Avatar
Ok I l kw you said you didn’t wanna mention which transmission. But would you tell me lol so I would know which one to go for cause as of now the k my one I can figure out is the f40 transmission. I will build up the transmission or pay a shop to do it! Thanks you!
Old Apr 17, 2018 | 06:02 PM
  #78
fieroguru's Avatar
He used the F23 from 2000-2002 J body with the 2.2L engine (non-ecotec).
Old Apr 18, 2018 | 07:41 PM
  #79
bgordon86's Avatar
Did he have to do any modifications for the starter on the ls4
if you use the f40 tranny you will have to modify the tranny to fit the starter on
Old Apr 20, 2018 | 09:50 PM
  #80
fieroguru's Avatar
There is a bolt-on starter bracket that works for the LS4/F40 and LS4/F23 transmission. It places the stock LS4 starter in its stock position, just requires some trimming to the bell-housing case. Google...
