Hooker 1964-67 A-body LS swap system preview thread
#301
Tod, Where can people source these Torca couple clamps?
#303
I've been accumulating my parts to swap an LS3 into my 66 Chevelle.
I've received From Holley
forward bias Motor mounts, 302-2 oil pan, valve covers and fuel rails.
The SS 1 7/8 long tube headers are supposed to ship next week?
The SS 3" exhaust is still Processing?
Today I received my crossmember, solid piece.
I must mention though, the packaging was not that great on the crossmember. Having three heavy metal pieces put in a box with minimal packaging material lead to the pieces moving around and tearing the bag containing the hardware and damaging the box. I ended up missing 4 of the 3/8 nuts and although they weren't listed on the parts list there were only two 7/16 washers.
I am really happy with the quality of the components I'm getting from Holley. If my swap lives up to that same quality I should have a sweet ride.
#304
I had the same issue with my crossmember, but worse. The only things in my package were the driver's side brace and the actual crossmember. It was missing the hardware bag as well as one side brace. A call to Holley and they sent replacements. Good customer service. I am waiting for the extensions of the mid-length headers to the exhaust to be manufactured so I can order. I need mid length as my car has airbags and gets too low for long tubes.
#305
Did you get the exhaust system from Holley also? if so have you actually received it?
#306
I appreciate you guys sharing your feedback of the packaging of your crossmembers and will be relaying your experiences to the appropriate product manager to review the packaging requirements.
#308
I contacted Holley yesterday about the missing hardware. The gentleman I spoke with couldn't have been more helpful, we went over all the parts and even came up with a few pieces I didn't even realize were missing.
Unfortunately, he called me back latter to inform me that he contacted the warehouse and the parts were not available, and wouldn't be for the foreseeable future. He suggested I could return the whole crossmember in exchange for another one, I can't see how that would be any better.
Disappointing to say the least. Most of it just hardware store nuts and bolts, but that is not the point. I paid for the quality of the Holley kit.
#311
#312
Not sure if this has been asked , did not read the whole 12 pages but , I think 64s are different , than 65 thru 67 , as in a larger front crossmember , I know mine required major surgery for the rear of the crossmember
#313
The geometric differences in the 64 frames have no affect on the fitment of the Hooker components that I'm aware of. What engine mounts and oil pan did you use in your project?
#314
Todd I did mine 5 years ago so it was a gm musclecar pan , you guys have made it alot easier with 302-2 , and trailblaser ss manifolds , and the like , I know many manufactures list 65-67 chevelles because of the uniqueness of the 64s , do you know of any customers that have done a "trouble free" install with you system in a 64
#315
#316
What do you think the differences are? I've been running a 1964 El Camino frame under my 1965 body for years. First a 396/4-speed, then a 454/4-speed changing to a Richmond 5-speed and then a 454/Richmond 6-speed all of which had an OEM GM Chevelle BBC oil pan which had plenty of clearance with respect to the crossmember. Currently I have done a body off update to a Dart Aluminum EFI 565/gForce T56 with no fitment issues related to the frame. I don't imagine there should be any problem with the Hooker LS conversion.
#317
I can relay the same on the packaging of the crossmember. Thankfully, our small parts bag didn't fall out until it was in the shop. We did order the engine brackets at the same time during the end of year sale. At the time they were listed as estimated ship date of 1/8/17. I see now that the store lists preorder ship date of 2/10/17. I can understand these are made in batches, and weather here in eastern Oregon has shut down the freeway for days at a time from December through January, but I am getting close to wanting to install the engine. Was there a higher than expected demand for the production run?
#318
#320
The driveline geometry obtained by the Hooker mounting components is the same for all transmissions. I obtained 2 degree U-joint operating angles on the 65 Lemans I had in the shop that was lowered 1" all around...I used a 1350 yoke on a 3" diameter shaft to do the mock-up and the shaft/yoke were probably 5/8" from the tunnel.
