Alternator slop
Old Mar 22, 2016 | 05:00 PM
jozw30's Avatar
Default Alternator slop
Installed my alternator and grabbed the pulley to give it a spin for the heck of it and noticed the internals seem sloppy to the pulley. Not comepletely independent of each other but loose for a quarter turn or so?
Is this normal?
Old Mar 23, 2016 | 05:07 PM
Pop N Wood's Avatar
Doesn't sound normal to me.
Try torquing down the bolt holding the pulley to the rotor.
Old Mar 23, 2016 | 06:09 PM
jozw30's Avatar
So I looked at this some more and what I'm seeing is it's not "sloppy". I stuck a small screw driver in there to block the internal parts from moving and tried to rotate the pulley.
Clockwise, it's solid (the internal rotating assembly is one to one) but if I rotate the pulley counter clockwise and block the internal assembly, the pulley will rotate with little resistance.
Old Mar 24, 2016 | 06:53 AM
jozw30's Avatar
Can anyone confirm that this is OK? All you have to do is use a screw driver to stop the internal fan from rotating. If you turn the pulley counterclockwise, will it keep rotating even thought the internal motor parts do not?
Appreciate it.
Old Mar 24, 2016 | 07:51 AM
truckdoug's Avatar
i tried on a couple spare alternators, none of them do that
Old Mar 24, 2016 | 09:29 AM
jmd's Avatar
jmd
Pictures and application details are helpful.
sounds like a clutched pulley.
Old Mar 24, 2016 | 12:20 PM
homemade87's Avatar
Thats normal . My alt does the same thing . If you quick turn it one way and stop quick with your hand it will still rotate a little . I thing GM designed it for the inertia of the alt to eliminate the belt from getting slack under quick throttle blips . It will free wheel a little and allow everything to catch up .
Old Mar 24, 2016 | 09:04 PM
jozw30's Avatar
Cool! Thanks!
It's is out of a 2006 GTO.
Old Mar 24, 2016 | 09:10 PM
jozw30's Avatar
Homemade87. That's exactly what mine does. It's only got 18k miles on it, I was hoping it was ok..... Just felt weird.
Thanks again. I'll move on to the next goofy problem.
Hope everyone has a nice holiday!
Old Mar 24, 2016 | 11:30 PM
gofastwclass's Avatar
Corvette alternators have one-way clutches built in and I think certain GTO's did too. The F-Body cars do not and neither have any trucks I've worked on.
Old Mar 27, 2016 | 10:49 PM
truckdoug's Avatar
whoa, didnt know that. GM is crazy.
like the caddies with the cooled alternators wtf?
Old Mar 28, 2016 | 11:16 AM
Project GatTagO's Avatar
http://www.rockauto.com/en/moreinfo....432739&jsn=423
One way clutch. Keeps the alternator spinning as engine slows down.
Andrew
