LS3 pricing?
Old Mar 31, 2016 | 02:38 PM
WICKD 81's Avatar
Default LS3 pricing?
Hey everyone, this is my very first post, so your help is greatly appreciated. I have the opportunity to purchase a used LS3 with 43000 miles on it that came from a 2008 Corvette. The motor is complete from oil pan to intake including fuel lines. Also has all front accessories, ECU, and wire harness. I have the opportunity to purchase it for $5,700, is this a good buy or is it too high? I'm not very experienced with this as I'm just starting out in the LS world.
Old Mar 31, 2016 | 02:51 PM
Project GatTagO's Avatar
A new LS3 is $5900:
http://www.jegs.com/i/Chevrolet+Perf...01326/10002/-1
So think of it as getting free accessories, ECU and harness. However, a stock harness is not plug-n-play and the Corvette accessories may not fit your chassis...
So the final answer is "It depends."
Andrew
Old Mar 31, 2016 | 03:01 PM
Kharp's Avatar
I just bought an LS3 and Andrew is right on the money!
Old Mar 31, 2016 | 03:05 PM
WICKD 81's Avatar
I probably should have also stated that this is going into my 1981 Corvette comma which has a turbo 350 auto trans.
Old Mar 31, 2016 | 08:47 PM
jimmyg's Avatar
I would buy a new one. Unless used one is in car running, you really don't know how it is on the inside. How was it stored? Was the oil changed reg? Etc...
Old Mar 31, 2016 | 10:43 PM
1981TA's Avatar
I got a used one from a 08 Corvette, complete, from a guy in Schererville IN. Engine was in great shape, but needed a swap harness and programmed ECU. Bought the engine for 3700, but now I have about 4500 into it (including new timing set).
Old Apr 1, 2016 | 09:27 PM
chuckd71's Avatar
I paid $3kish for an L92 that had been swapped to 24x and arp rod/ head bolts, new rings etc. Spent another $700ish on cam/springs/valves and $300 on an LS3 intake, so $4,000 more or less. The extra $2,000 vs buying new ($2,700 when considering cam) buys a T-56.
Having said that, other than being able to say it's there, for practical purposes I'm not sure what a 6.2 will do that a 5.3 or 6.0 wouldn't.
Just starting out you might consider getting a cheaper motor running to iron out the kinks. Once you get one in, swapping it out is pretty easy.
Old Apr 2, 2016 | 06:38 AM
Pop N Wood's Avatar
Damn. Hard to believe used LS3's cost nearly as much as a new crate motor.
Keep in mind a crate motor does come with a 12 month warranty.
Old Apr 2, 2016 | 12:36 PM
lscorvet's Avatar
5,700 no way. I bought a LS3 416 for $4,000 no ECU, harness and accessories
just buy a new one !
