First attempted startup- Leaking Injector?
Every time I stopped cranking the engine, I heard a hissing sound from what seemed to be the front passenger side of the engine, possibly in the area of the fuel rail. Does this sound like the symptoms of a leaking injector? It's loudest as soon as I stop cranking, then slowly dissipates over 30-60 seconds. Or is this the normal sounds of the fuel pressure regulator relieving pressure (or something else?)?
Is it normal for the pump to kick back on for 2 seconds after failed cranking?
So I start checking things, spark first. Pull the fuel pump relay, pull the wire off cyl #2, put an extra plug in it, ground the plug to the exhaust manifold, turn the key to on, and use an external starter button to turn it over. Goes around once...got spark! ...and immediately after #2 fires, the engine starts.
With no fuel pump.
On 7 cylinders.
And it proceeds to run for at least a good 15 seconds. Seemed fairly smooth for 7 cyl, but couldn't really tell, as I was in a state of shock.
So I put everything back together, and.....back to square one. Still won't start again. Even re-created the scenario that it started in, and it won't again. What the hell?
I'm going to sort that out better once I get everything running, see if I need a later model switch.
I've bypassed the crank position for now though, I have a pushbutton temporarily wired in between 12v keyed and the starter relay so any key-related issues should be eliminated.
Any recommendations on injector cleaning? Solution/method?
