5.3/T56 68 Camaro
Old 03-05-2018, 11:30 PM
  #81
seanb128's Avatar
Got my bell after waiting for a while. Just have to get some hydraulics and a clutch kit.
Old 03-08-2018, 05:47 PM
  #82
seanb128's Avatar
So I have everything I need for the most part, I am going to fab up my own trans crossmember. I ordered the LUK Clutch kit 04-173, and I think the LS7 one is 04-905. I'm hoping that even though it was fairly inexpensive it will hold up. I also got a slave cylinder, and a set of ARP bolts so I'm hoping that'll be a good clutch job. Going to try to get most of it installed over my spring break so I'm not fighting issues with it this summer. I also got pigtails for the VSS and RLO, the VSS does say coolant temp sensor but I was assured that it was a speed sensor and if not I can return it. I think T56 and th350 use the same yoke? I could be wrong but I put a th350 yoke in the output for just a dust cover and it seemed to slide right on.
Old 03-08-2018, 05:51 PM
  #83
seanb128's Avatar
Also that pigtail for the RLO could be wrong. If it is I can just return it.
Old 03-09-2018, 09:37 AM
  #84
ryeguy2006a's Avatar
Did you get the pigtail for the Reverse lights too or are you doing something different with that?
Old 03-09-2018, 11:35 AM
  #85
seanb128's Avatar
I haven't figured that one out yet, how did you do yours?
Old 03-09-2018, 12:32 PM
  #86
lizeec's Avatar
Drastically over paid on the slave, usually most all of them are made by AP and run in the $75-100 range at most. You still need bellhousing to motor bolts, bellhousing to transmission bolts, slave bolts, while in there it is a very worthwhile investment to get a speed bleeder for your slave.
Old 03-09-2018, 02:37 PM
  #87
seanb128's Avatar
Okay.. I have trans to bell bolts, included with the bellhousing I bought. I also have bell to block bolts. If needed I can go to a local hardware store to get slave to trans bolts. I heard about a speed bleeder and was thinking about getting one.
Old 03-12-2018, 09:57 AM
  #88
Looking good. I am going to get a speed bleeder too. I wished I would have just done it when I mated the trans to the motor earlier...
Old 03-12-2018, 12:35 PM
  #89
seanb128's Avatar
It might make life a lot easier when trying to bleed it ha
Old 03-12-2018, 09:45 PM
  #90
seanb128's Avatar
Got my order, and hope to have it installed over my spring break but we’ll see. I’m going to try and build my own cross-member and see what I can come up with. I know there’s polenta of people on here that have built their own.
Old 03-13-2018, 08:45 AM
  #91
Stampede4ever's Avatar
What is the clutch for, LS1?
Thanks.
Old 03-13-2018, 09:46 AM
  #92
seanb128's Avatar
Thanks.
Yeah LS1/6 I believe. The Luk 04-905 is the LS7 if I remember right.
Old 03-13-2018, 12:39 PM
  #93
Thanks, that's what I plan on going with, the ls1 or ls6. Where did you order from, and is that an ACDelco? Seems high to me, or I gamble on part store parts.
Stampede.
Old 03-13-2018, 01:50 PM
  #94
seanb128's Avatar
Stampede.
I ordered this off Summit. And it’s a Luk, I thought I read somewhere that they are the ones who build the OEM clutches for GM. Note that it doesn’t come with flywheel-pressure plate bolts.
Old 03-16-2018, 01:41 AM
  #95
seanb128's Avatar
Finally got around to installing master cylinder. I just have to TIG the sleeve with the heim joint that came with the bracket. Fits awesome, no issues with it. Even told you where to drill hole on clutch petal for the new setup. I have some pictures of it, but they don’t really do justice with how dirty my firewall is. I’ll have to clean it again.
Old 03-17-2018, 05:01 PM
  #96
seanb128's Avatar
Might be a shot in the dark, but is there a fuel pump system that you can put into the stock tank? I understand there’s in-tank pumps, but is there any drop in system specifically for First gen?
Old 03-17-2018, 05:27 PM
  #97
Chevy Kid's Avatar
Holley has a new drop in system for a stock first gen tank.
Old 03-17-2018, 05:37 PM
  #98
seanb128's Avatar
Awesome, thanks!
Old 03-17-2018, 10:44 PM
  #99
LS1 pwrd NOVA's Avatar
Did you use a stock ls1 master cylinder for your hydraulics?
I can’t decide which master to go with yet for mine but I need to buy my shirt and finish my swap.
Old 03-18-2018, 12:11 AM
  #100
seanb128's Avatar
Yeah just LS1 master, and speedtech bracket. Was just bolt in basically and pretty nice quality as well.
Quick Reply: 5.3/T56 68 Camaro
