P0171/4 Codes - About to torch the car...
Car is an 87 IROC-Z, engine was pulled from a 2003 GMC Savana van, 4.8L, 4L80e including full harness and computer, sent the ecu out to have emissions and rear O2's deleted, came back and engine ran perfect, at time of install one year ago I installed a new fuel pump and FPR, engine has been running fine up until one day it fell on it's face as I pulled onto the highway, a couple minutes later the codes popped up, luckily I only had a couple miles to go to get home.
symptoms - rough idle, hard to start, would almost die if given any throttle
replaced MAF sensor with new - no change in condition
checked vacuum lines and replaced all - no change in condition
replaced intake gaskets - wont start AT ALL now
checked fuel pressure at rail - 58 psi steady
checked signal to all fuel injectors with noid lights - all firing
checked all coils and plugs - all firing
checked exhaust, no leaks - true dual from headers back so wouldn't think both banks would go at once
thought it possibly could be O2 sensors but not sure they would both go at the exact same time
also accidently cleared codes and since it wont start now cant check freeze frame data
I'm stuck on where to look next and in dire need of some advice
Last edited by Dustin Fritz; Jul 8, 2016 at 09:28 AM. Reason: aditional information
the O2's you should be able to disconnect and run in open loop, and you should get DTC's related to that unless the reprogramming prevents that;
not sure if MAF would cause hard start or no start, it is said disconnecting the MAF can sometimes help in troubleshooting - that it'll default to a speed density type of calculation for fueling the engine and that should allow it to run fairly well.
with handheld observe the MAP reading, if the engine is not starting then it should at least read atmospheric with key on, and when cranking with throttle closed the reading should drop... at least do a sanity check on the map reading to make sure it's valid.
otherwise i would start looking at cam and crank sensors, i think those are the most likely given your symptoms... if not a bad sensor a bad/pinched/burnt wire that's messing up that signal.
and you say all of a sudden fell on it's face, i would also inspect all the engine/PCM wiring looking for something that's chaffed or pinched.
I do have access to a tactrix cable, although their software doesn't currently support any GM vehicles so it's unable to interface with the ECU, unless someone knows of some open source software that's compatible?
I don't know how the regulator works at the rails, but for me I was just able to replace the Vette regulator and it was all fixed
im running the stock FPR at the rails, brand new a year ago and still getting 58psi
I went out and inspected every wire, unplugged every sensor and took the intake back off again to check if i had pinched anything and didnt find any issues, reinstalled everything meticulously and plugged all sensors back in
gonna unplug O2 sensors and see if anything changes after lunch
again - MAF is new, cant find a vacuum leak anywhere both visually and with starter fluid
Lets discuss the non-running issue and try to fix that before moving back to the codes
I've verified each coil and plug is firing, engine is at least getting fuel, pulled plugs and lightly set them in hole and fire shoots out each cylinder
From what I am hearing, the only thing I can pin it on is probably the computer itself. Make sure you didn't disconnect it by accident somehow, and if you have anywhere you can borrow another identical computer from, you can try swapping that so see if it will start/run. Even if the VATS shuts it off after a few seconds, you can still verify if the computer is causing your no start issue.
I've replaced the maf, crank sensor, cam sensor, spark plugs, verified spark and fuel pressure while cranking... Would bad O2 sensor cause it to not start?
Assuming you do not have cats on this car, I would pull the plugs and see if they are gas fouled. If they are gas fouled, where is your fuel pressure regulator? You said you had an express van engine. If it still has the truck intake, does it have the return line fuel system?? If so, check the fuel pressure regulator. This regulator pulls vacuum from the engine, and when the diaphram fails, it will suck gas through the vacuum line and flood the engine. I had this problem on another LS swap I did and it took forever to finally figure out the regulator was bad. Once the regulator was replaced (and the gas fouled plugs) the car ran like a champ.
Good luck, and please update when you figure it out.
Ricky
