Keith's 65 Impala Upgrade
To make a long story short.......Some of his friends removed the old drivetrain and parts not required and I gave him a list of parts to order and the car showed up today with the parts.........So.....Put the Pop corn on as it will be an Honor to help Keith out.......
Here is the car arriving today.....
New Holley 302-1 Pan installed
Stay Tuned........
Ken, you should have been there when I went to the Pull-A-Part in Birmingham. It was 3:00pm on a day when the high was 99 degrees...and 80% humidity...
Andrew
A mans go to do, what a mans got to do !
My cars not even on the road and this ones cleaner than mine.
You should think about using a II Much fuel vent on your builds.
https://www.iimuch.com/collections/f...erential-vents
I am planning on installing on in the Cougar soon.
Andrew
Andrew
I have one in the Chevelle..............
Andrew
Really admire (and envy) your builds! Thanks for the posts. I'm living vicariously a bit as I'm between projects with my swap completed and also out of garage extra space. My wheels turn when your builds progress!
I installed this long tank breather with inexpensive air filter atop and get no vapor smell in the garage nor trouble when filling. With the braided hose and AN fitting, probably $40 worth. Nice breather product though! I'm assuming a vent similar to mine could be threaded in a car / wagon application into a wheel well or trunk cavity so the filter is above the tank level.
If this info dilutes your build thread here, let me know, I'll delete the post.
Those fuel filter adapters with the blue plastic clips always scare me...
Earl's makes a really nice one with metal retaining clips (needs a simple tool to remove and it has a secondary retention clip.
https://www.holley.com/products/plum...ts/AT991966ERL
Andrew
Andrew
