Porsche 997 C4S LS Swap
Old 08-07-2017, 10:04 PM
  #161
shanghai_todd's Avatar
I'm now torn between using the turbo bumper with quads or modifying my C4S rear bumper for center GT3 style center tips. Also throwing around the idea of center quads similar to the Techart 991. Looking for something different and to make it stand out from the typical 997's.
What do you guys think? Center quads to much over the top?
Old 08-07-2017, 10:36 PM
  #162
White Out's Avatar
Don't do quad tips.
Center with two tips looks really good.
Old 08-07-2017, 10:55 PM
  #163
Romulus22's Avatar
I like the top the best personally. the bottom two are too crowded looking.
Old 08-07-2017, 11:12 PM
  #164
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
2 Pipes look Powerful.
4 pipes look fussy.
IMHO
Old 08-08-2017, 06:38 AM
  #165
LQ4-E39's Avatar
4 pipes reminds me of the C7 Vette, I can just imagine this thing with the 2 center tips throwing flames
Old 08-10-2017, 10:58 AM
  #166
Tncumminsguy's Avatar
love these 911 swaps!
Old 10-15-2017, 10:17 PM
  #167
Amille28's Avatar
I'd like an intake like that. Could you PM me where you got it? Is Profab local to you?
Old 10-24-2017, 08:51 AM
  #168
Tuckin15s's Avatar
Very clean and well put together swap!
Old 11-01-2017, 07:07 PM
  #169
Well it's been awhile since my last update and with the weather cooling off in Florida I can finally work out in my garage again without having a heat stroke.
Found a drivers door and hood locally and the beast is starting to look like a car. Still need to get the passenger quarter repaired and I picked up a pair of Gambella GT500 side skirts from Extreme Motorcars. Not sure if I will keep this frontend or go with something more aggressive before painting but I got several months before I need to decide. Figured at this point I should go all in and make this bitch over the top and sinister.
Exhaust will be getting done in 2 weeks. I have had several change in directions on this so everyone will just have to wait to see..
Old 11-01-2017, 07:18 PM
  #170
One other small update, K&N airfilter.
BTW, anyone experience issues with the clutch slave cylinder and using a stage 2 or higher clutch? Just pressed my clutch in to find it stuck to floor and now I have hydraulic fluid dripping out fron the bottom of my engine adapter. Pretty sure the seal exploded but won't be able to pull it out till I return from my business trip.
Old 11-02-2017, 06:55 AM
  #171
Tuckin15s's Avatar
Photobucket won't let us see your photos.
Old 11-02-2017, 04:48 PM
  #172
dcd215's Avatar
I would bet the slave wasn't centered -it's hard to see up there .I know because it happened to me .It felt tight and it was crooked jumped off the throwout arm and popped the dustcover and piston out .
Old 11-02-2017, 10:33 PM
  #173
Photos fixed
Old 11-03-2017, 08:46 AM
  #174
michaelmaxim's Avatar
Subscribed! My Dad is a Porsche guy and I'm an LS guy... sharing this with him so he can see the best of both worlds! He's got the last year of the air cooled 993 cars and his keeps increasing in value... Now if I could only convince him to do an LS swap.
Old 12-19-2017, 07:59 PM
  #175
Dropped the car off to Profab on Friday and they killed it again with the exhaust. I pick it up tomorrow and the suspense is killing me on how it's going to sound, also the fact that I will actually get to drive the car for the 1st time..
Old 12-20-2017, 12:13 AM
  #176
White Out's Avatar
Looks great!
Old 12-20-2017, 10:53 AM
  #177
The beast is back at the house and time to troubleshoot the electrical gremlins. Car does not want to idle and I can hear a relay in the back clicking when under 1k rpms and then car dies.
Things that work:
- oil temp gauge
- water temp guage works to 175f then won't read any higher. Using the LS sensor in the head and probably need to wire in the Porsche sensor.
- cooling fans are coming on at 200f and temps drop down once kicking on.
Things not working:
- tachometer (need to program my Dakota Digital and make sure I am pulling the right signal wire) RPMs reading on ODB handheld
- idle dies out under 1k
- slave cylinder not fully disengaging when pressed and sticks the last 2". Pretty sure I just need to bleed it again and have some air in the lines.
Plan for the day is let her run for 5min and bring her up to temp a couple cycles with 30min breaks so that I can burp the coolant system and check for any leaks or other problems.
Old 12-20-2017, 11:54 AM
  #178
Received 3,149 Likes on 2,456 Posts
That car is pure nasty, in the absolute BEST way!
Old 12-20-2017, 12:12 PM
  #179
Jimbo1367's Avatar
We can't get the videos to play.
Old 12-23-2017, 03:48 PM
  #180
Well after months of starting the car and 1 short drive around the neighborhood the engine is officially blown..the video below is 5min before the internal destruction... I had the wife record the short video and decided I wanted to hear it myself outside the car and had asked the wife to start it up and should have specified how much throttle to apply . It was loud for 3-5sec followed by black smoke and a metal to metal crunch. Coolant in the tank disappeared and engine no longer cranks or will turn over. I'm guessing a rod went and won't know for sure till next year when I decide to pull the engine apart. Not how I was hoping to spent the new year but **** happens and now I have an excuse to go bigger and forged.
Quick Reply: Porsche 997 C4S LS Swap
