A-Body LS powered T56 swappers step on in...
I traded out the 4L80e I installed with my LS swap for a T56, and it was probably the best thing I've done to the car (including the LS itself). Pull the trigger and enjoy it.
I'll echo what many others have said re: master/slave/clutch. If you're trying to keep it relatively budget, go with the f-body master* (maybe do the drill mod) and slave, the adapter plate mentioned above, definitely the remote bleeder, and LS7 clutch. Spring for a Pro 5.0 or MGW shifter and you'll be set.
*I got a tick master with my T56, so I can't comment on the OEM m/c with or without the drill mod.
