no alternator plug on Painless harness
My LT1 painless harness did not have this either.
On the 99 and up PCM's, the PCM controls the LAMP line directly.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
The engine/pcm/loom are for year 2000 Camaro
The other 2 wires (battery and fuse box) should indeed go to the stud on the alternator.
www.speartech.com
www.speartech.com
No, the other 3 connections are for other functions, that aren't used in this application.
www.speartech.com
I may have misinterpreted, but the single wire that runs from my PCM to the alternator is the exciter wire, yes? To cut this wire and connect a bulb into it would mean that the bulb would be turning on all the time, wouldn't it?
The other terminals are not used in this application, and you shouldn't try and use them for anything, but they are:
S = the Sense lead. used to sense the charging voltage. It's done internally on our alternator.
L = Lamp terminal. This is the one used to turn on the regulator either thru a lamp, a resistor, or let the PCM do it on 99 and up applications.
F = Field terminal. Can be used to control the output by controlling the field voltage. Some applications let the PCM control this terminal.
I = I forget what this one even does
. I don't think any applications use it that I know of.
www.speartech.com
