Lower driver side truck alternator mount
Hey all- I don't have hood clearance for the truck intake or ridiculously high alternator mount.
I know most of you drill and tap the truck block for the fbody alternator bracket but I am running my manifolds down and forward for a turbo setup and am concerned about clearance and heat damage to alternator and wiring. Anyone have more details on mounting directly to the block like the pic below?
I am prob going to use an l99 waterpump for It's right forward output to match my older sbc better.
I think an alternator bracket that fits on the driver side top but lower maybe where dirty dingo idler relocation bracket goes would be ideal and then skip the idler?
Maybe like this if someone knows who makes this one attached below? Happy holidays!
the last pic in this post shows it pretty good. right to the block with some 1/4" thick washers.
and I think I lied to ya, thats some sort of f body pump possibly.
https://ls1tech.com/forums/conversio...l#post19454118
My 2K Z,
That is the only Dirty Dingo FEAD that actually looks good IMHO. Never knew that existed. truck spacing w/fbody location. . This should help some people.
thanks fior sharing?
The Holley kits do the same
https://www.holley.com/products/ls_p...s/parts/20-162
I thought the Kwik performance kits could be adjusted for different belt spacing as well.
I never seen this style from HOLLEY before. Anyone have any pics of it completely assembled on a engine?
I think ICT also makes truck pulley low mount -- http://www.ictbillet.com/ls/brackets...nk-pulley.html
My 2K Z,
