Mustang notch LS build
Old Jan 12, 2017 | 03:25 AM
  #41
Lsxnafox's Avatar
Originally Posted by learning91
ok my 92mm tb came in ,mounted it up, i also put the alt. on...test fit my 2" steel cowl hood..it hit...not as bad as i thought..i massaged an inner brace about 1/2" it sits flat...but i bought a new alt. for it and that did not clear...so i compared it to the old alt....the original alt. has a smaller body casting than the new one...i put old one on and it clears!! heres a few pics
Nice!! Glad you figured it out, hood seems to look great too!!!
Old Jan 12, 2017 | 03:30 AM
  #42
Lsxnafox's Avatar
ok, i've got some questions for ya!! what throttle cable and bracket are you using..my stock cable looks like it might work out, no sure....on your serpentine setup...
what length belt are you running?.does the belt rub at the idler?
thx!!
I'm using the factory truck throttle cable I had to modify to get to work. I got some fittings that let you adjust its lenght I really need to get a nice lokar cable. Check out the build txfireman1972 is doing on his notch build thread on here he did it right with the lokar cable. As for the serpentine belt, I'm running manual power steering so I deleted the power steering pump had to search in Google and found the length. If you really need it I'll get it for you.
Old Jan 25, 2017 | 04:32 PM
  #43
jaywill's Avatar
nice build ! i fixing to start on a 89 coupe lq4 build...
Old Jan 27, 2017 | 06:46 PM
  #44
markster's Avatar
Do you have a picture of which way you mounted the aje mounts on the engine block?
Old Jan 27, 2017 | 08:27 PM
  #45
TxFireman1972's Avatar
Here is a thread about it:
https://ls1tech.com/forums/carburete...05505-aje.html
Old Feb 2, 2017 | 04:04 PM
  #46
6D9's Avatar
6D9
Very nice! I was thinking about going to the same tuner when my LS project gets done!
What converter are you running?
Rear gear??
Any track times ?
Old Feb 12, 2017 | 06:53 PM
  #47
Lsxnafox's Avatar
Finally made it to the track. Really pleased with the outcome. The car ran great no issues at all and made 8 passes yesterday. Best all motor was 11.9@ 120mph. My last pass I sprayed but my bottle only had around 3 pounds left over from the dyno session. I really only felt it in first gear and then power went away.
Here's the pass I did on nitrous.
Old Feb 12, 2017 | 07:02 PM
  #48
Lsxnafox's Avatar
Rear gear??
Any track times ?
Still running the stock converter and really suffered from it yesterday at the track. I couldn't foot brake at all and had to basically leave off idle. Couldn't get a 60ft better than 1.9, converter coming soon haha.
I'm running 3.73 rear end with a 28in tall tire that seems to be a good combo as I was crossing the line at just about the top of 3rd.
You won't be dissapointed going to starkweather. Nathan really knows his stuff he was at the track yesterday and took the time to help me out. He noticed I was leaving off the line like **** so he put some more timing down low.
Old Mar 19, 2017 | 12:10 PM
  #49
Lsxnafox's Avatar
One last video before pulling the exhaust and starting the turbo build.
Old Jun 11, 2017 | 10:35 PM
  #50
AFTER HOURS MOTORSP's Avatar
The 450 pump worked in that Pro M fuel hat?
Old Jun 11, 2017 | 11:59 PM
  #51
Lsxnafox's Avatar
Yep, it was a tight squeeze but still working great. Making 600 wheel on e85 with a turbo now.
Old Jun 12, 2017 | 03:57 AM
  #52
Stampede4ever's Avatar
Could you post some pics of the turbo setup?
Thanks.
Old Jun 12, 2017 | 07:24 AM
  #53
dmracing's Avatar
Thanks.
https://ls1tech.com/forums/conversio...rbo-build.html
Old Dec 13, 2017 | 01:49 PM
  #54
mxendres's Avatar
hey what did you do for the pcm/engine harness? nice build though
