C4 corvette
Old Jun 24, 2004 | 06:36 AM
yak's Avatar
yak
Default C4 corvette
I got one question; will a LS1 clear the hood of a C4 corvette with an LT1?
I'm stuck between swapping an Ls1 into a 3rd gen or a C4 vette. Any help would be great, thanks a lot guys.
Old Jun 25, 2004 | 12:33 AM
C4VetteLS1's Avatar
yes it clears just fine.....
The swap is a direct bolt in, no fab work needed. Its unbelieveably easy to work on in a c4 chassis. I can pull the motor in 30 minutes on a lift. Last year I literally did head gaskets in 1hr 10 minutes on my lunch break.....almost too easy...
Old Jun 25, 2004 | 12:34 AM
C4VetteLS1's Avatar
Old Jun 25, 2004 | 08:37 AM
yak's Avatar
yak
wow that looks nice.
Being 16, its a pain to get a fast car with cheap insurance, so I was gonna go 3rd gen camaro or C4 wit an LS1. Looks like the C4 may be better. Do I need to get different motor mounts? what about the electronics and such? Thanks for your help.
Old Jun 26, 2004 | 03:25 PM
C4VetteLS1's Avatar
Nope, direct bolt in using street and performance motor mount plates ($80) and stock c4 motor mounts....
Electronics? well the dash harness etc is fairly independant of the engine harness. Cut out the engine harness, and the interior wiring/lights/everything else runs on its own seperately...Used a painless wiring harness for the engine...
Plan on spending $5k doing the swap including motor/trans
Btw: dont do a 3rd gen camaro if you can help it, the c4 will weigh minimum 500 lbs less, it hooks better, and is a better basis for dragracing/road racing applications
Old Jun 28, 2004 | 02:24 PM
93Polo's Avatar
What headers are you running in the C4?
Old Jul 6, 2004 | 09:03 PM
C4VetteLS1's Avatar
MAC 98-00 LS1 headers...
I cut the collector off and added my own piece of 3" pipe on them, they bolted right on.
Which you can see in this picture on the bottom after i had them ceramic coated
Old Jul 7, 2004 | 12:40 PM
93Polo's Avatar
Very
