Need help with cooling fans please.
Presumably the ECU has two setting for fan temps, a low point and then a higher setting.
Andrew
so need a diagram for dual fans. I used this one which uses dual fans and also dual speeds.
One relay switches the fans between series (low speed) and parallel (high speed) configuration
- One relay provides power (half-current due to series operation) to both fans in low-speed mode, and just fan1 in high-speed mode
- One relay provides power to just fan2 high-speed mode.
The high speed signal from the PCM controls both the series and fan2 relay. The low speed signal controls just the fan1 relay. For both fans to spin in high speed mode, both signals are needed.
Andy1
