Need advice for pre start checklist!
Hello all,
I'm putting the finishing touches on an LS swap into my 3rd gen camaro. The car is H/C/I with every seal, sensor and accessory replaced.
I'm real nervous about hitting the key for the first time. Scared even. Within the next week or two it will be time.
Any pre/post start suggestions?
Then finding no leaks, reconnect the coils and fuel pump. Shouldn't need to crank it much. Mine started in about 1/2 a rotation. Then do a double check on leaks & electrical issues.
Now build a punch list once it runs. This is everything from suspension, to tire pressure to electrical gremlins. Be sure the D-shaft is bolted down, cross member bolted down and so on.
I made a paper list that gets marked off as I go. Keep it until you test drive the car and know that everything is right.
Jim
Jim
Good advice will do. How noisy should the motor be on first start up ?
A claw hammer is mandatory equipment on any build! Not for the car, but to scare the kids away!
Make sure you have a water hose near by in case there are bubbles in the cooling system and it burps and drops your coolant level.
On the sprints most of the engine guys I know are using the joe gibbs break in oil so the contact parts get enough zinc to surface harden correctly.. It has that once old smell too it,, like its bad for you,,, gotta love it..
Check for leaks, let temps come up, check for fans coming on (assuming electric), etc. I like to have the car ready to actually drive when first start up is close --- if no noises, pressure and temps are good - go for a ride and check drivability. May want to change out initial oil/filter somewhere in the first 100-1000 miles. Mine fired about 1/2 a second after the first turn of the key and settle right into a 600-650 rpm idle --- like it had been running that way for years.
Oh - if you're running a mass air set up, be sure all your air inlet piping hoses/fittings/clamps are tight/secure. I had some minor leaks between mass air sensor and the throttle body -- set off a check engine light that took some head scratching to figure out. Seems my ecu (08 Corvette) compares mass air readings to what it's seeing form the MAP sensor -- and if air flow calcs don't jive, it sets a check engine light. Cleaning up/greasing some rubber/clamped connections solved the problem.
Fear not -- turn the key!!! The sooner you do, the sooner you'll find any problems you'll have to correct. Because I already have another car using it -- I used Honda antifreeze and distilled water in mine.
