Lsx swap rear end
Old Mar 10, 2017 | 08:45 PM
boostedbuckets402's Avatar
Default Lsx swap rear end
I have a 1998 mustang v6 ill be swapping a 6.0 lq4 into soon, im wondering what rear end i should use? Is it a ok idea to run the stock one to get everything set up and upgrade when it goes out or would i need a different length driveshaft with another rear end compared to this one? Thanks for any info i know the stock one probably isnt rated for much but if i can get it moving under its own power with that rear i would be happy, also would i need to upgrade the whole diff or just the gears? if i can keep it in there for a little bit ill probably weld it or have it welded just because its a open diff and thats no fun at all, thanks again!!!!!
Old Mar 11, 2017 | 06:25 AM
GonHuntin's Avatar
By "welding it", do you mean welding the spider gears? If so, that is a very bad idea for a street car and maybe even worse for the track! Welding the spider gears will eliminate any differential action in the rear end. When you make a turn, the real wheel on the outside of the turn must travel farther than the one on the inside, the differential action of the rearend allows this. Welding the spider gears will force the inside tire to travel the same distance as the outer and the only way that happens is by spinning the inner wheel.
If you are talking about "welding it" for the track, if the stock rearend isn't strong enough for the new power, welding the spiders won't make it stronger. Most likely, you will either break the spider gears at the weld, or you will break something else.
Your 6 cylinder car should have the 7.5" rearend, your best bet would be to buy an 8.8 out of a v8 powered mustang and put it in your car.
Old Mar 11, 2017 | 07:36 AM
ok so I'm looking for a 8.8 and thanks I know it's probably not the most idea way but I know I'm not the first person to weld it
Old Mar 11, 2017 | 08:00 AM
truckdoug's Avatar
you can find a clutch type posi from an explorer 8.8 and put that in. they are very common.
ive run welded diffs before. not really a big deal with street tires.
but, i wouldnt do it in a c-clip rear again. launching an axle at speed is a highly ***-puckering experience
Old Mar 11, 2017 | 08:06 AM
ok thank yea it's just going to be a street car but I've heard of someone using the whole explorer 8.8 rear end on a truck
Old Mar 12, 2017 | 10:21 AM
Lsxford's Avatar
IIRC its pretty involved to put the expo rear in a mustang. The GT 8.8 is pretty strong and should be easy to find, and its a direct swap
Old Mar 12, 2017 | 10:24 AM
ok cool I'll look around junkyards here for one, thanks for the info I'm having to figure a lot of this stuff out on my own
Old Mar 12, 2017 | 10:57 AM
Lsxford's Avatar
Theres no need to figure this stuff out on your own. Theres thousands of swaps just like this lol
Edit: i believe the pinion flange is different 7.5 to 8.8 so if you find 1 grab the shaft too
Old Mar 12, 2017 | 10:25 PM
I know i guess i didnt realize how common it was to swap a ls into a mustang hahaha
Old Mar 12, 2017 | 11:32 PM
slocaddy's Avatar
Ok, (knuckles cracking......) while I'm no expert, I've done my fair share of 8.8 reserch, for my jeep(exorer 8.8) and the caddy(grand marquis/crown vic)
Do not do an explorer housing, the pumpkin is offset, the mustang 8.8's are centered.
Do use the explorer's posi unit, as truckdoug said, they will be easier to find along with a wide array of gears, the other benefit is they will be set up for 31 spline axles, witch I don't think your genration of mustang came with unless it was a cobra.
The axle in your car (edge mustang) was used from 98-04, the actual housing is wider than the previous years sn95 mustangs , not to say one out of an earlier gt wouldn't work, but You will have to consider your wheel/tire/offset combo to fit the car.
Old Mar 13, 2017 | 12:24 AM
pdxmotorhead's Avatar
The small late 90's lincoln has the 8.8 with disk brakes as well, and it uses the same pickup points as the small mustang rear end as I recall,, been a while..
Old Mar 13, 2017 | 01:31 AM
my 98 is the sn95 style I think people get confused about that the new body style was changed in 99, is the gt differential open or posi? And either way I think I'll be looking for that and those gears/ posi
thanks
Old Mar 13, 2017 | 06:12 AM
billymgb1000's Avatar
I put a 8 inch in mine with a mini spool. the mini spools are so cheap I paid 25.00 and don't have to worry about the welds breaking. I swapped a l/s into a 74 MGB weighs about 2200 lbs and she is a convertible. fun fun fun. good luck with your swap.
Old Mar 13, 2017 | 06:20 AM
ill have to look into that thanks
