Foxbody notch lq4 turbo build
Old 10-19-2018, 02:30 PM
  #161
Sourskittle's Avatar
Originally Posted by Lsxnafox
Just to update on the the car, I pulled out the motor tore it down replaced the pistons. Bearings looked perfect. Turned out to be the blowoff valve making that noise lol.... Also, the car is for sale....
i just listened to a rant from Matt (sloppy Mech) about how he never runs a blow on any turbo ever lol.
Glws
Old 10-19-2018, 09:47 PM
  #162
Lsxford's Avatar
Glws
he put 1 on the Colorado, just for fun because someone sent him 1.
Old 10-28-2018, 11:24 PM
  #163
Lsxnafox's Avatar
With the boost at about 20psi the car now makes 855hp and 729tq. This little 7575 turbonetics turbo has been putting in some work... Tq is low because I didn't have a lock up switch wired in. Timing was only at 12 degrees.
Old 03-06-2019, 07:36 PM
  #164
Lsxnafox's Avatar
Finally got around to installing the bump box I made a while back. This is all stuff you can get off Amazon.
A multifunction delay relay timer and relay. Seems like it's going to work very nicely.
Old 03-08-2019, 10:32 AM
  #165
panda240ss's Avatar
thats some goood *** power man!
soo i guess ima be staying in the 10-15 lbs area lol
Old 04-21-2019, 09:24 PM
  #166
Lsxnafox's Avatar
Bolting on a larger turbo. Borg Warner S476 should allow the motor to breath much better compared to the small 7575.
Old 04-22-2019, 08:22 AM
  #167
FowlerMotorsports's Avatar
This thing should make some serious power considering your 7575 made some serious power. When do you plan to tune and dyno this thing?
Old 04-22-2019, 09:38 AM
  #168
Lsxnafox's Avatar
I was surprised how far the small 7575 went great turbo.
For now I'm actually going to turn it down to 16psi with this turbo. I'm in the process of building a forged 6.0, then I'll turn it up to 20psi. I'd imagine it's gotta be close to 1000 wheel. Should be done in the next few months.
Old 04-22-2019, 09:42 AM
  #169
Lsxnafox's Avatar
Pulled the junkyard 4l80e for rebuild. The clutches were burned. Got a billet input shaft and some good clutches in it. Also ordered a Jake's d3 brake. My goal is to be in the 8s this year.
Old 04-22-2019, 09:45 AM
  #170
Lsxnafox's Avatar
Finally took care of the rear suspension. I was still running the factory upper control arms. The bushings were shot ofcourse. Went with upr fully adjustable and their solid heavy duty bushings. The pinion angle was way off. Went to the track a few weeks ago and man what a difference, car feels planted and went nice and straight.
Old 05-22-2019, 02:12 PM
  #171
Lsxnafox's Avatar
Got the car all wrapped up and to the Dyno to adjust the tune for the larger turbo. Made 892hp on about 20psi on 12 degrees.
Old 05-23-2019, 07:43 AM
  #172
LSswap's Avatar
Nice!!
I see numbers on the car.. Go to the track already on the new turbo?
Old 05-23-2019, 10:03 AM
  #173
I'm surprised you made only 50hp more than the 7575. Still more tuning needed to be done?
Old 05-23-2019, 12:03 PM
  #174
Lsxnafox's Avatar
We lowered timing from 16 degrees to 12 to so hopefully save the rods. Tuner is one of the best in the area, he knows how to help these sbe motors live. Also, this is a different Dyno which the tuner said typically reads around 50 to 70hp less.... We'll see how it does at the track coming up in June but the motor has to be breathing better now...
I'm in the process of building another 6.0 with forged internals so we can really take advantage of the turbo...
Old 05-23-2019, 12:04 PM
  #175
Lsxnafox's Avatar
Originally Posted by LSswap
Nice!!
Not on the new setup haven't washed the car since the last track day lol... I should make the test and tune at Famoso June 8th..
Old 05-23-2019, 10:58 PM
  #176
I missed the timing part. Still very impressive numbers for your build
Old 05-24-2019, 10:54 AM
  #177
Stampede4ever's Avatar
How much were the UPR control arms, and bushing?
Thanks.
Old 05-24-2019, 11:09 AM
  #178
Lsxnafox's Avatar
Thanks.
I got it all from their website.
200 for the control arms and 120 for the bushings I got the extreme series which are a bit larger. Their bushing removal tool made it super easy to remove and install the bushings.
Old 05-24-2019, 07:15 PM
  #179
Also, how did you run your down pipe? Looks tight for space.
Thanks.
Old 05-24-2019, 08:58 PM
  #180
2JZFC's Avatar
Very nice!
Quick Reply: Foxbody notch lq4 turbo build
