Ford 8.8 axle question
Old Apr 8, 2017 | 03:34 PM
jozw30's Avatar
Default Ford 8.8 axle question
Tried to search didn't find an answer for my question. Planning to shorten an explorer D4 code 8.8 rear to center drive shaft.
Can I use any passenger side short axle even if it's not from a "posi" 8.8? Found one already unbolted from another rear thats not D4 coded explorer. It's from the correct year range though....
Thanks!
Old Apr 8, 2017 | 05:20 PM
Project GatTagO's Avatar
I don't see why not, as long as the spline count and length are right. Diff type has nothing to do with the axles...
Andrew
Old Apr 8, 2017 | 08:13 PM
Lsxford's Avatar
Andrew is correct. As long as its from an explorer itll be fine.
Old Apr 9, 2017 | 10:43 PM
64post's Avatar
Are you doing that to run 31 spline axles as well?
Old Apr 10, 2017 | 08:55 AM
Just to add, diff splines must obviously match axle splines. I also believe that all Explorer 8.8s used 31 spline axles and diffs.
Andrew
Old Apr 10, 2017 | 10:28 AM
Lsxford's Avatar
Andrew
That is also correct. The IRS exploders are obviously different but all standard straight axles are 31 spline
Old Apr 10, 2017 | 10:47 AM
The IRS diffs are also all 31 spline. So if you find a IRS with limited slip, you can swap that diff, etc...into a standard housing.
Andrew
Old Apr 11, 2017 | 07:38 AM
jozw30's Avatar
Thanks, just shortening to center and get the width I need.
I just wanted to make sure that the non-posi short axle was the same part as I lucked into finding one already loose at the yard. Just save me some work when I go back to get a full assembly....
