GM muscle car oil pan
Old 07-14-2017, 06:55 PM
Toddoky's Avatar
Originally Posted by JoeNova
Whoa, that's awesome!
Thanks, we believe it will provide benefits to a lot of users.
Old 07-14-2017, 07:07 PM
Received 3,145 Likes on 2,452 Posts
Originally Posted by ls1nova71
Curious, where did you see just the pan? Everywhere I've looked its the pan, pick up tube and windage tray.
My bad! The pan always comes with tube and baffle, along with plug, bypass cover, etc. The choice is if you also want the gasket kit for it included.
Old 07-14-2017, 09:23 PM
1973 STEP A SIDE's Avatar
Originally Posted by Toddoky
This will soon not be the case with the coming 302-3 Holley pan...stroker clearance up to 4" and turbo drain-back ports along with that capability. If fits every application the 302-2 fits and then some.
About time you slackers get what the people need !!
Just hope it not like the 68/72 El Camino trans cross member !!
Old 07-14-2017, 09:40 PM
Toddoky's Avatar
That crossmember has taken an extended amount of time as it got pushed back in favor of other projects a couple of times. I'm going to grease the wheels of that project next week and get it jump started.
Old 07-15-2017, 12:07 AM
That sounds great Todd !! I will be waiting for the good news !!
This means more money going to Holley for parts . LOL !!!
Old 07-15-2017, 05:12 PM
dad599's Avatar
I'm in for one of those too
Old 07-18-2017, 02:32 PM
Fierro51's Avatar
302-2 pan on a 77 impala with holley engine plates and solid engine mounts
1 3/4" of clearance between the top of the x member and the pan maybe a little more
Old 07-25-2017, 05:22 PM
procomp's Avatar
Well I went with the oil pan from BRP and will be using all their mounts as well. Thanks for the feedback.
Old 07-25-2017, 10:07 PM
ls1nova71's Avatar
Originally Posted by reedld
No, it hangs dangerously low ( I had it in my car ).
Originally Posted by Russ K
Save yourself a lot of trouble and look at the Holley LS swap system. The only oil pan to be able to get the engine low enough is the Holley 302-2.
Originally Posted by BlueMagicSS
I built a 67 Camaro and used the GM Muscle Car Pan against my better judgement and ended up having to lift the engine to replace it with the Holley Pan. In short, save yourself the trouble and go with the Holley from the gate.
Originally Posted by tracetrimble
I have BRP mounts which set the motor pretty high, and the GM muscle car pan. Here's a pic of the situation. I'm gonna go with it for now, but I may regret it.
Ok, so let me see if I got this right.... You got these answers ^^^ And still decided to go with that pan to save $100? Good luck with it....
Old 07-25-2017, 11:09 PM
procomp's Avatar
I didnt realise the BRP kit used the GM pan, I thought it was their own pan and shorter. Will order the Holley.
Old 07-26-2017, 03:48 AM
ls1nova71's Avatar
Unless they've changed recently, as far as I know they have always used the LH8 pan, which is the Hummer pan and also the muscle car pan. I dont think you'll be disappointed with the Holley, I have heard nothing but good things about it.
Old 07-26-2017, 06:45 AM
  #32
dlwilson's Avatar
Here's the GMPP muscle car pan in a 1979 El Camino with MetalTek mounts. It hangs down lower than I want, but I'm going to use it for now to git her done. Google says the C5 Corvette oil pan that came on the engine might work(?!), otherwise I'll eventually put the Holley pan on.
Old 08-04-2017, 10:11 PM
  #33
brian1971's Avatar
I tried all of the GM truck and hummer pans,ended up going with the 2004 CTS-V pan and it worked out great.It's about the same size as holley pan.
Attached Thumbnails GM muscle car oil pan-20170630_213438.jpg   GM muscle car oil pan-20170625_181431.jpg   GM muscle car oil pan-20170630_213042.jpg
Old 08-10-2017, 02:05 PM
  #34
ryeguy2006a's Avatar
So glad that I stumbled onto this thread on the 302-3. I am getting dangerously close to needing an oil pan and will eventually have a turbo. So the drains that are cast into the pan are a very nice feature. Nicely done. Todd, please keep this site updated when you know the availability of the new pan.
Any idea of the price point? I'm sure it will be more than the 302-2, but how much more?
Old 08-10-2017, 02:26 PM
  #35
Toddoky's Avatar
I have heard the pan is getting close to being available, but I don't have a specific date to report as of yet.
The price point is also not something I'm informed about as I'm not the primary responsible engineer on this project...I provided the basis for the geometry/features of the design and someone else ran with it from there. When I hear something I let you guys know.
Quick Reply: GM muscle car oil pan
