LS3 Erod overcharging, WTF
Engine is properly grounded, alt the cables have less than .1 voltage drop. I swapped the alternator and the ECU with new ones right out of another Erod we have sitting here in the box, same thing. I ohmd the wire from the L terminal on the alternator back to the ECU, pin 7 grey connector E67 ECU. Its fine, I can command the L terminal on and off with a scanner and the alternator charges and stops charging like its supposed to in the test mode, and the ECU sees the correct voltage in the data stream, 17v and up. I have 5v on the alternator plug with it unplugged but I havent checked the duty cycle with it plugged in and running. This is a PWM triggered alternator.
What the hell am I missing here? First one Ive had do this, all I can figure is there is something going on in the harness im missing, though its unlikely cause I can command full field and no field with the scanner. Or something like a ground isnt pinned right at the ECU connectors? This is just too wierd at the end of the day on a friday haha. Any thoughts at all?
http://www.lateral-g.net/forums/showthread.php4?t=55174
Andrew
It has a 4 pin plug but only has an L and F marking on the plug. Its a DR44G I think, the regulator so far as I know is setup for PWM only. Id be happy to just hook up switched ignition to it if that would work but the 25888970 alternator I dont think would like that, unless someone tells me otherwise. I know the regulators that have PLFS I can get away with a switched source, but this is only L and F
I have to add this to my very very short list of cars I couldnt fix, not for lack of trying, but for time and cost reasons...bummer. But the vehicle will be here for a little while still while we do our test miles.
Further down, pin 29 is the gray wire labeled "generator field duty cycle signal".....
The fact that you can cycle the charging circuit shows it's good, but it doesn't help you regulate the output voltage of the alternator.....just a guess..
T,
System Operation
The basic operation of the RVC system is
covered here, but not all systems will enter all
modes of operation; refer to the applicable
service manual information for more details.
The purpose of the RVC system is to maintain
the battery state-of-charge at 80% or
above and support vehicle loads.
The six modes of operation include:
• Charge Mode
• Fuel Economy Mode
• Voltage Reduction Mode
• Start Up Mode
• Windshield De-ice Mode
• Battery Sulfation Mode
The PCM/ECM (generator battery control
module on full-size trucks) controls the generator
through the generator L-terminal control
circuit. It monitors the generator performance
though the generator field duty cycle signal circuit.
The signal is a 5 volt PWM (pulse width
modulated) signal of 128 Hz with a duty cycle
of 0-100%. Normal duty cycle is between 5-
95%. The ranges between 0-5% and 95-100%
are for diagnostic purposes. The accompanying
table shows the commanded duty cycle
and output voltage of the generator.
The generator provides
a feedback signal
of the generator load
circuit to the control
module. The signal is
a 5 volt PWM signal of
128 Hz, with a duty
cycle of 0-100%.
between 5-99%. The
ranges between 0-5%
and 100% are for
Charge Mode – The control module enters
Charge Mode whenever one of the following
conditions is met:
• Under WOT conditions and when the fuel
rate (sent by the ECM/PCM) is greater
than 21 g/s and the throttle
position is greater than 90%.
• The headlamps are on, low or high beam.
• The wipers are on for more than
8 seconds.
• The electric cooling fans are on
high speed.
• The rear defogger is on.
• The Battery SOC (state of charge)
is less than 80%.
Here's the table...
Duty
Cycle
Generator
Voltage
Set Point
10% 11.0V
20% 11.56V
30% 12.12V
40% 12.68V
50% 13.25V
60% 13.81V
70% 14.37V
80% 14.94V
90% 15.5V
T,
I wish I knew how the setup was supposed work with the LS3 GMP controls pack, then maybe I could further diagnose. But at this point, i went down every path I could think of, replaced every part I could, and seeing in multiple ECMS the alternator control turned off, makes it even more mysterious how the E-rod ECU is supposed to handle the charging system.
