LS3 standalone harness, oil pressure sensor
I have a a new wire harness for a ls3 motor and I believe that I am missing the oil pressure switch that connects to the motor. Attached is a picture of a blue oil pressure plug from the wire harness. I am looking for the oil pressure switch that connects to the motor and takes this plug. I was having trouble finding one and making sure that it will work with the plug I have.
Yeah I saw that and that takes a circular plug where my blue plug is like half a circle. So do I need a different oil pressure sender for the plug that I have?
The instructions that I have provided two different part numbers based on the year of the motor.
GM# 1216646 for 2008 and older
GM# 12621234/ Delco #213441 for 2009 and up
I am not exactly what sure the year is for my motor, so I looked up those two part numbers and was trying to determine which will work with my blue plug. Thanks for your help!
Mine doesn’t look exactly like yours, but it has 3 very small connectors like yours in the same pattern. I was not able to find a oil pressure switch that matches mine either. I hooked up an external gauge off the oil cooler block, but it always bugged me having the wire just hanging there.
Looks like part#12596951 sensor
