Early LQ4 - 71 Nova Build - Billyfargon
#342
Any time I have an engine-related noise, I try to evaluate the following: how does the sound change with engine speed, engine load, and transmission in/out of gear or clutch in/out? For each case does the sound get louder quieter, faster, slower, or the same? These are really important clues for where the sound might be coming from. For example:
- If the sound is the same volume but faster with higher engine speed, I'm thinking valvetrain rocker adjustment / pushrods
- If the sound gets quieter and faster with higher engine speed, I'm thinking oil pressure related, also possibly valvetrain lifters
- If the sound gets louder with load and faster with higher engine speed, then I'm thinking exhaust leak.
- If the sound doesn't get faster with higher engine speed, then I'm thinking it's not engine related. It could be as simple as something rattling against something else, like insufficient exhaust clearance.
Based on what I can hear in the video, I would pull the valve cover (easy enough to do) and make sure all the rockers are tight and not wondering around. I had a bent pushrod w/ loose rocker make noise like this once where the rocker would wonder around on the tip of the valve and I guess depending on where it happened to land each time, the noise would get louder or fainter or outright go away some times, so it didn't have the regular sewing machine of a valvetrain noise. I think something similar could possibly happen if the lifter is not getting good oil flow.
Another thing I've experienced that sounded similar was loose flexplate bolts. You might want to get under the car and check the bolts at the flywheel/flexplate and see if anything is loose or getting knocked around in that area.
Just ideas. Hope you find it!
I agree that's usually the case.
#344
I appreciate the ideas! I will mess around with it this weekend and check some of these things and report back.
Its always good to get outside opinions or ideas.. Sometimes I get so focused on one aspect and fresh thoughts help!
#345
Wanted to update this thread before I get too far behind...
My buddy decided he needed more power than his Lexus so he bought a Camaro. Size comparison with the Nova is not as far off as one would think.
I got my Holley/ Hooker turbo exhaust manifolds cerakoted. Happy with how they turned out. Got them mocked up on the spare LQ4.
I have never done a turbo so I am figuring it out as I go. In the meantime I decided I would get my spare LQ4 broke down, check it, clean it, add a few things to it and replace the LQ4 I have right now. Im just tired of the random ticking and I figured since I should really gap the rings before I run turbo that I would jump ahead and prep the other motor.
Plans for spare 6.0 are:
Gap the rings
cam & springs
oil pump and timing set
head refresh
With these basic things done I will swap it into my car, get it tuned for new cam, then I will feel good about adding the turbo to it afterwards.
Then just a few extra shots for the heck of it
Gap the rings
cam & springs
head refresh
#346
Been a good while since an update on here! I keep my Instagram and YouTube channel updated so I figured I better catch this up with a few details.
Turbo-Prep:
1. Transmission - Started rebuilding my first transmission ever. Spend a lot of the time reading and trying to figure it out and not a ton of time actually working on it but its just about ready to start re-assembly. I went with a Jakes Stage 2 kit but then ended up buying the upgrade input shaft anyway. Hoping this actually works when I install it!.
2. My spare LQ4.
Got it all cleaned up and put back together. This is basically a cookie cutter sloppy setup. It has gapped rings, Sloppy Stage 2 cam, new timing chain set, melling 10295 pump, new summit lifters and trays, PAC 1218 springs, BTR pushrods, ARP head bolts, refreshed heads and now ready to go.
My plan is to swap out trans first and make sure it works all good and if it does with no issues then I will pull engine and put the newer one in. After engine is in I will get it tuned N/A and make sure its all dialed in. Once that is done I will start working on getting the turbo kit installed. Really thinking about going to terminator X even though my stock harness and computer work good so I can start learning tuning so I dont have to take it in every time.. so we will see. That may happen when I put new engine in.
Other than that.. I refreshed the front end a little with a new front bumper and a Glasstek 3" chin spoiler.
Turbo-Prep:
2. My spare LQ4.
The following users liked this post:
BillyFargon (11-03-2020)
#349
Be aware some of the cheaper lifter trays have been know to let the lifter rotate and cause ticking
#351
Quick update:
Built 4L80E is done and installed. Went with a Yank pro-series billet triple disc converter. Now I just need to fix a weird noise I am hearing from car so I can get some miles on the transmission before I pull and swap engines.
#352
Hey man, enjoyed the videos and following along with this build. The extra block painted bright green is different and looks good. Did you just use rattle can on all that? Also I see you installed ARP head bolts and not studs. How much boost and hp are you planning on? Reason I ask is everyone has a different answer. Some reuse stock stuff, others studs others new bolts.
#353
For the paint on the green engine its engine primer and color that's made for high heat. I wouldn't recommend using just regular paint. The engine specific paint uses ceramic in it which makes it more durable. There may be other reasons but that's the one that sticks out to me. There are lots of colors to chose from too and it all comes in rattle can.
I honestly don't know the science of strength on bolts vs studs. I think studs probably hold more power but maybe someone else can chime in. I didn't want to reuse stock bolts or even buy new stock bolts just for the simple fact is that you aren't supposed to reuse them and I wanted bolts I could reuse. You're right though.. people have had success reusing stock bolts but that's not something I want coming back to bite me down the road. This is my first turbo build so there is a good chance I may have to pull heads again for maintenance or possibly blowing a gasket from inexperience.
As for boost levels and power... I would like to be 600-650... and I am hoping to get there around 15lbs which is pretty safe but we will see.
#354
Sounds good on the paint. I’m looking to make what you are to the wheels but with a blower.
BillyFargon (02-01-2021)
#356
Update time... plans have changed big time! My car was heading in a direction that was not matching the type of driving I was wanting to do with it. It was heading in more of a drag racing setup and I want a street car capable of sliding corners.. drifting and autocross.. So I stopped right where I was at and basically sold off all automatic stuff that was in my car... trans, crossmember, shifter, driveline... etc... then I even ditched the turbo direction I was heading.. For the driving I felt that NA would be the best most simple and reliable way to proceed.
So car started getting torn down again:
Modified factory harness was removed and I am currently installing Terminator X Max. I bought the Max so it would control trans and turbo and now its a little overkill but oh well.. its already paid for.
I also took the fresh rebuilt 317 heads off the 6.0 Im going to use and put fresh rebuilt 706 on instead which will be better for NA. While I was in there I did a cheap BTR trunnion upgrade and got my stock injectors all freshened up. So the replacement 6.0 is all good to go just about ready to go back in.
About a month and a half ago I ordered a Tremec TKX 5-speed swap kit from Silver Sport Transmission. Trans is still on back order but I did start getting parts in this last Sunday to start getting the rest of the car prepped. I want to loom the trans wiring in with the Holley stuff and have that all clean and loomed so that's what I am working on now. Then I will get the clutch mounted with bell housing and get that all centered so I can get engine in car all just waiting on trans to get here
And now I have 3 pedals!
#358
The following 2 users liked this post by -TheBandit-:
BillyFargon (10-06-2021), G Atsma (10-05-2021)
#360
