S10 - Anyone makes AC hoses for low mounted Denso Compressor ? Make my own ?
Does anyone makes bolt on AC hoses for low mounted Denso Compressor ?
Did some searching but not finding anything!
What fittings would I need to make my own?
Thanks
Waid
Thanks
Waid
The following users liked this post:
SadaJones (05-30-2023)
Several years ago I couldn't find a shop to make up hoses (small town) so I purchased a kit to do my own. The kit has paid for itself doing several of my cars and other street rodders cars. Most aftermarket systems use O ring style fittings but a few older systems still use flare fittings. Your factory compressor will have to use the bolt on factory fittings but everything else is available aftermarket (hoses, dryer, O ring fittings, O rings etc.). Your choice DIY or farm out.
I found another link with correct updated part numbers:
http://www.s10forum.com/forum/f213/a...s-swap-561754/
https://coldhose.com/
Part #BL9328: #12 90-Degree O-ring Fitting (Old number C198)
https://coldhose.com/12-90-degree-o-...ting-3568.html
Part #BL1307: #10-#12 Straight O-ring Fitting (Old number A137)
https://coldhose.com/10-12-straight-...ting-2335.html
Part #BL9305: #8 Straight O-ring Fitting (Old number A195)
https://coldhose.com/8-straight-o-ri...ting-4206.html
Part #BL1322: #8 90 Degree O-ring Fitting
https://coldhose.com/8-90-degree-o-r...ting-4307.html
Part #BH12: #12 (5/8") Barrier A/C Hose Per Foot
https://coldhose.com/12-5-8-barrier-...-per-foot.html
Part #BH8: #8 (13/32") Barrier A/C Hose Per Foot
https://coldhose.com/8-13-32-barrier...-per-foot.html
Compressor fittings: http://www.apairinc.com/iView.asp?Ca...or%20Manifolds
451-1106 (Denso 10S20F/10S17F to #10 adapter block)
440-823 (Seal for ^ block)
451-1105 (Denso 10S20F/10S17F to #8 adapter block)
440-822 (Seal for ^ block)
Go buy a hose that the compressor came off of and cut off the fittings on the end and put the fittings you need on. This will work a lot better and look way more professional than just building them from scratch.
I have no tech to add to this thread, except that if you want a really clean look, use some quality heat shrink tubing (like Raychem) over the metal part of the crimp on the hose end. This will give a really nice finished look to the hose assembly.
Andrew
Andrew
I believe the 99 and 00's use a different compressor than the newer ones. I know the size "shrunk" a little I think in 04 or 05? But I still thought the take off lines were/are the same.
Hoping you will be able to tell me where i can get a low mount for a denso ac compressor?
Appreciate some direction if posdible.
Waid hasn't been around for over 2 years.
