t 6060 trans mods needed for a LS3 69 camaro
Old 12-20-2017 | 03:37 AM
2fastforu's Avatar
Default t 6060 trans mods needed for a LS3 69 camaro
I have a 2012 donor camaro LS3 t 6060 that im putting in my 69 camaro. I want the shifter to be in the stock 69 location. I hear I have to put a T56 tail on the t 6060 but some machining is required. Can someone give me some details on all that is required to do this please?
Old 12-20-2017 | 07:01 AM
1964SS's Avatar
This might at least give you an idea of whats involved.
http://www.ddperformance.com/bk5-con...060-to-magnum/
Old 12-20-2017 | 06:31 PM
rickpaw's Avatar
You still need to modify the stock shifter opening on the trans tunnel. Core shifter makes a kit that mounts to the top access cover hole, and eliminate the remote shifter on the TR6060.
Regarding the driveshaft, the driveshaft shop makes an adapter/CV joint that bolts to the flange, or get a Sonax u-joint adapter.
Old 12-20-2017 | 08:01 PM
2fastforu's Avatar
I'll call D&D. I didn't see much for a 69 Camaro swap but i'm sure they have or know what to do. I did see a not on there that said the console would have to be modified and I'm not wanting to do that. There has to be a way to get that shifter in that factory location.
I'd like to get my trans done first so I can make a trans mount and get the pinion angle set. I'm sure the LS3 and trans will be in an out a few times before I get everything how I want it.
Old 12-20-2017 | 08:04 PM
2fastforu's Avatar
I was wondering if there would be a problem using a CV on one end and a U joint on the other. Is it still the standard 3 deg. standard?
Old 12-20-2017 | 08:07 PM
2fastforu's Avatar
Thanks for all the data Rick and 1964SS. I never imagined all this information would be out there.
Old 12-21-2017 | 09:36 AM
rickpaw's Avatar
It shouldn't be a problem. Plenty of people have done it. This guy's thread is a perfect example of a TR6060 swap.
https://ls1tech.com/forums/conversio...68-camaro.html
Personally I would not want to do the D&D magnum conversion due to the cost/time involved.
Quick Reply: t 6060 trans mods needed for a LS3 69 camaro
