1954 Chevy 3100 5.3
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/69dcc4a4_2453_4bf3_a4f4_c8d5f9bf3802_7664b7c85e4e122feaf75a46396e547dcfae7126.jpeg)
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/c247c627_fe56_4768_a861_e0c330bb2673_a2f99d6c77827b9f0d807b963f7d7ddd2680801d.jpeg)
So I picked up this truck back in July 2017 it had 250 i6 with a TH350 but it just isn’t cutting it for me. I been doing some research and reading some of the build threads and I decided on going with a 5.3 with a 4L60E that I’m getting from a buddy of mine. Luckily the 5.3 is still in the truck so I’ll be able to get everything I need.I know speedway makes a set of mounts and plenty of other companies do too but what are some of you guys preference as far motor mounts and trans crossmemebrs.
I went with a set of Holley mounts which allowed me to reuse my El Camino stock cross member. I love your model of truck and the Apache that came after it. I will try to follow your build as you get going.
Rick
Rick
Suspension/chassis
-Air ride Mustang II with power rack
-4 link rear end w/ bags over axle, c-notch
-Blazer rear end with disc breaks
-under floor power break booster, all new brake lines
-blast, prime and paint chassis
Drivetrain
-5.3L with a 4l60e
Body/paint
-Fresh paint
-light rust repair in the floorboards and cab corners
-holes in firewall filled
-steel wheels and whitewall tires
Interior
-a/c, radio, wipers, and gauges
-new apolstry
Drivetrain
-5.3L with a 4l60e
Body/paint
-Fresh paint
Interior
-new apolstry
Dirty Dingo mounts allow you to move the engine back and forth to help with cross member location. Nice truck, those are getting rare especially the 5 window.
Love these trucks!!
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/f6f0d3d7_eed0_411e_bda9_0f659994d1f5_cbda2c34269ac6eee7a97af1a553b23b09ebb95f.jpeg)
![](https://cimg8.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/e6c580fc_52a4_4ba3_bd14_f8592d84daa4_96d563e79a0da1738e0fffa429d34d40e249c468.jpeg)
I used some althread to get my centers dead right on the spring hats.
Just a little update doesn’t seem like much but I got the old suspension off. The rivets on the old leaf spring brackets I had to grind down the head and drill most of it out than punch them out. I also got the MII crossmeebr tacked in and assembled, I’m satisfied how it all turned out.
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/f9325427_7117_4fd7_a3f9_14403128ad62_a129137140cace5a2db00cce6b87b8b93305829a.jpeg)
The accuair Endo CVT and E-level kit finally came in. It took me 5 weeks to get this thing. The compressor and sylinoids are built inside of the 5 gallon tank, it’s suppose to be really quiet so I’m planning on mounting it behind the seat where the gas tank was at.
