lm7 swap into g body
Not revving could be something as simple as the throttle cable being too long or the butterfly jamming. Other idea that jumps to mind is lack of fuel pressure or flow. The fact that it starts and runs definitely narrows it down some.
it has 60psi fuel press at idle goes to 65 off idle it's a cable throttle body hooked up fine the tps and map and maf are ok ? the pcm was sent out for the security only code is a p0605 mil control circuit I don't have the bulb wired in
If its still expecting the trans that the PCM came with, it'll cause issues.
The PCM will use all of the Park/Neutral tables, and might even trip the Bad VSS limiter. You'll have to change the MPH/RPM limits.
