WTB "Aussie cam" for LM7
If this is a lobe-profile only thing, can an LQ9 or LM7 be reground to those specs? (Low rev truck swap motors).
Anyone got dyno sheets of one?
https://ls1tech.com/forums/generation-iii-internal-engine/328246-best-low-end-torque-cam-ls1-7.html
In all seriousness, you just toss a low LSA onto a mild grind and you have what PatG was talking about. There's no such thing as an Aussie grind.
Must use oem stall for towing and 6l80e tune reasons
Motor is a lm7 with a .125" bore and LQ9 cam. If I can have Bullet grind the stocker for my low revs and spring pressures-I would be happy.
Was thinking of a 216/222 108LSA (+0)... 0.566" lift? I shpt Patric G a message but I am curious what you guys thing about that cam in a visually stock, awd Z71 with 4.10 gears with small (29") tires. Call it 325" cubes, as my 5.7L is pending a sale.
Will get a custom e85 tune but NO higher stall converter. No headers. Really dont even want to to a cat back exhaust until the OEM one rusts out.
