Best low end torque cam for LS1..
Old Jun 8, 2005 | 12:12 PM
  #121
Deeavi's Avatar
I have not posted in a while, but I saw this thread and thought I would chime in. My car is a daily driver, in and out of traffic. I had a 224/112 cam and it was lacking on the low end torque side.
I switched to a VINCE/Crane 056 cam with 216/224 dur @.050, 551 lift @ valve, and 115 degree LSA. It makes a ton of torque. I was having it dynoed when it broke the lockup on my TCI 2500 converter at close to 400 ft lbs of torque. My transmission has 106,000 miles on it so when we ran it unlocked it only pulled 367 ft lbs. of torque. I think you would like this cam. I love it! It pulls strong past 6000 rpms and it also has a nice choppy idle which I like.
Old Jun 8, 2005 | 12:15 PM
  #122
SSCoulter's Avatar
Thanks! That sounds exactly like the cam I want.
Old Jun 8, 2005 | 12:25 PM
  #123
Patrick G's Avatar
LS1 Tech Administrator
That Vinci cam is a good one, but not as good as that same cam on a 113LSA. It will be even torquier. Vinci sells that one too. They also sell the 113LSA cam with more lift. If I was going to buy a Vinci cam, THAT's the one I'd get.
But if you really want abundant low end torque, you're going to want an Ausie cam (smaller duration, narrower LSA). You won't get many recommendations for them because not many people in North America have tried them.
Old Jun 8, 2005 | 01:43 PM
  #124
SSCoulter's Avatar
Thanks, I was leaning toward the duration and lift he was talking about not the LSA so much. Thanks to you and a few others I am convinced the smaller duration, narrower LSA is the way to go. 216/224 midium lift and a narrow LSA is the ticket I think.
Old Jun 8, 2005 | 02:11 PM
  #125
patSS/00's Avatar
Why would smaller LSA = more low end torque? I thought for more torque you wanted less overlap = more LSA ...?
Old Jun 8, 2005 | 02:35 PM
  #126
Patrick G's Avatar
Overlap is amount of time the exhaust lobe and intake lobe overlap each other. LSA is only a small component of this. Duration counts much more.
For example
210/216 106LSA cam = 1 degree of overlap at .050"
220/226 110LSA cam = 3 degrees of overlap at .050"
230/236 114LSA cam = 5 degrees of overlap at .050"
So even though my LSA got 4 degrees wider in each successive cam, the overlap grew as well. LSA and overlap do not necessarily go hand in hand.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 8, 2005 | 02:45 PM
  #127
Deeavi's Avatar
With your M6 I believe the 113 LSA would probably be the better choice also!
Old Jun 8, 2005 | 05:57 PM
  #128
DaddySS's Avatar
I'd also like to results from a CheaTR cam on a headers or heads and headers car - I bet it will make some serious numbers.
Old Jun 8, 2005 | 06:11 PM
  #129
SSCoulter's Avatar
Thanks for everyone's input. I have decided to go with the Vinci 062 cam. Here are the specs.
"ASP-KICKER 2" Ultra torque cam
STREET / STRIP CAM - HIGH LIFT
POWER RANGE 1900 TO 6000
CRISP THROTTLE RESPONSE - LOADS OF "TORQUE"
" DRIVE - INN " IDLE
DUR @ .050" 210*/218*LIFT .551 / .551 OVERLAP 52* LSA 112*
Old Jun 8, 2005 | 06:28 PM
  #130
Corpsvette's Avatar
So will this have a lot of lope? Not sure what drive inn idle is. Love this thread. What to do, what to do?
Jim K
Old Jun 8, 2005 | 07:04 PM
  #131
SSCoulter's Avatar
Jim K
According to Vinci, it will have a nice consistent lope. Not like a real big cam that you can tell the computer is always searching for a smooth idle and the lope is always changing. They have a sound clip on their web sit of this cam. They are a sponsor here.
Old Jun 8, 2005 | 09:11 PM
  #132
SsZERO's Avatar
I've been reading a lot of cam threads, and this is probably the most interesting one. Right now I am running a TR230/224 "Reverse Split" cam on 111 LSA, and I would say it is "ok". With stock heads, u/d pulley, elec. water pump and hooker LTs I put down 370 RWHP / 359 RWTQ.
I am about to do a cam swap, and I pretty much want the same thing - more low end torque from idle on up. This cam I have now had a noticeable drop in low-end grunt, even with tuning.
Can someone recommend me a cam that will work well with the mods I mentioned and be able to pass state emissions? I do not care much if it is lopey or not. My current considerations were:
MTI Stealth Cam II
F14
TR CheaTR
TR Old Man Cam
Cam Mentioned in this thread:
https://ls1tech.com/forums/generation-iii-internal-engine/72972-224-224-110lsa-106icl-cam-dyno-results-very-happy.html
I like the idea of that aussie came with the low intake duration and higher exhaust duration...
Which of the above cams would pass emissions, and of those which would provide the best results?
Old Jun 8, 2005 | 09:45 PM
  #133
SSCoulter's Avatar
I'm glad I'm not the only one that feels this way. I don't give a crap about the dyno numbers. To many "Dyno Queens" running around out there now. I want a car that pulls like a freight train between idle and 6k. Stoplight to stoplight, yeah come get some.
Old Jun 10, 2005 | 04:22 PM
  #134
DaddySS's Avatar
Keep us posted on how it turns out!
Old Jun 11, 2005 | 10:48 AM
  #135
Cal's Avatar
Cal
I'd love to race you from stoplight to stoplight with my "over-cammed" dyno queen.
Old Jun 11, 2005 | 10:50 AM
  #136
SSCoulter's Avatar
Touched a nerve uh? lol
Old Jun 11, 2005 | 10:52 AM
  #137
Cal's Avatar
Cal
Nope, didn't touch a nerve with me. I just think you're missing out to go with that smaller cam. But then, I went with a small cam the first time too, and I think many people have wound up doing two cam swaps. Seriously, if you don't have it installed yet, I would consider trading it for at least a 224 cam. I doubt you could tell that "kicker" cam from stock if blindfolded. The stock cam is actually the best "torque" cam you could have. But what do you want, a tractor or a race car?
Old Jun 11, 2005 | 11:03 AM
  #138
PREDATOR-Z's Avatar
I think you are missing the point. TRQ and HP are directly related. Trq is what gives you a good 60' which is where 70% of the races are won. Why do people go big cubes? For more trq.
Combo, combo, combo
Old Jun 11, 2005 | 11:11 AM
  #139
blkZ28spt's Avatar
Combo, combo, combo
Yes, combo is where it's at. There is a reason that BIG cams are at the top of the "fastests XXX" lists. They make more power and when the car is set up for them, they are faster. (all else equal)
Old Jun 11, 2005 | 11:20 AM
  #140
Cal's Avatar
Cal
Combo, combo, combo
Torque is just rotational force, has nothing to do with energy. Horsepower is the time rate of doing work, and is what wins races. I could apply a large amount of force to a brick wall, but it the wall does not move, I've haven't done any work. Work is defined as applying a force over a distance, and is expressed in the same units as energy.
OK here's another example: A large diesel semi-truck has to pull huge loads up steep hills. It needs torque to do this, but we really don't care how long it takes, as long as it does it. The engine in this truck might only have 150 hp, but it has 600 ft-lbs of torque.
In contrast, a dedicated race car is lightweight and doesn't need a lot of torque to move it's weight. It may have only 150 ft-lbs of torque, but it has 600 hp. We are most interested in how FAST the race car can do it's job, not how much weight it can pull.
As for combo, take a look at his sig. He has an fbody, not a truck so he is not towing nor does he have a heavy vehicle. He has an LS1 engine with 4.10 gears, so he isn't hurting for torque at the rear axle. A better match for his combo is a cam with some duration IMO.
You probably think my cam is too big, but my dyno graph shows that it is putting out almost 300 ft-lbs of torque at 1750 rpm. That's a pretty low rpm to launch at, and capable of spinning any tire through 4.11 gears. Peak torque is 400 fl-lbs at 4800 rpm. LS1 engines are putting out as mush torque as big block engines did in the old days.
