The GMW - E36 with a 5.3 and a CD009
My swap headers came in from CXRacing. Once the engine is in I will install them. I am pretty happy with the quality of the headers considering what they cost in respect to other E36/LS swap headers.
The other critical part that arrived is the Collins trans adapter needed to mate my CD009 to the my T56 bell housing. I can't say enough about this adapter. It is a super nice piece, and a very well thought out kit. It is a shame it will never be seen again once everything is bolted up.
Got the bell housing mounted, and cut the CD009 bell house off. I ran out of break cleaner and time so I will have to wait till next weekend to get everything bolted together.
Should have more progress next weekend, and the goal is to have the engine in the car by the end of the month. That would be a big milestone, and will allow me to start getting everything plumbed. After that I will need to finish up the brakes, suspension, and drive train. Then it will be time to paint. There is still a long way to go, but it is encouraging to see progress.
Hope you guys enjoy!
Once I got the bell housing cut off the CD009 I mounted up the Collins Adapter, and bolted up the T56 bell housing on. Let me say that the Collins Adapter plate is top notch, and went together very nicely.
Once the transmission was back together I got everything bolted together.
Now that the trans was on the engine it was time to cross a big milestone off the list, and get the engine in the car. I was honestly very surprise at how easily the engine and transmission went in to the car. My father in law helped me, and we had it knocked out and bolted up in 45 minutes. I still need to level the engine a little (1/8" or so), and make the transmission support and mount.
I am thinking something like this for the trans mount.
Hope you guys enjoy the progress!
Again good luck with your build. My E36 LS swap was a great driving car.
Once the trans is in its final resting place I plan to wrap the headers and get them installed. Once the headers are in I plan to plumb the fuel system, finish the power steering, and wrap up the engine wiring. I hope to have the engine running in the car by this summer. Let me know if you have any questions. I would be happy to help if I can.
The actual trans model is FS6R31A. There is an FS6R30A, which is the 6 speed found in the Frontiers and Xterras. It has a different gear spread.
FS6R31A: 3.794, 2.324, 1.624, 1.271, 1.000, 0.794
FS6R30A: 4.368, 2.518, 1.743, 1.283, 1.000, 0.769
I am not telling you what to do, just relaying my experience...
Andrew
I've already got a spare T56 in my basement, otherwise I might have to think about the CD009 as well. The short 1st wouldn't really bother me, since my application is going to be a road course car; 1st won't be used for anything but rolling through the paddock.On the gearing front, the 1st gen CTS-V T56 has a 2.97:1 1st gear. The car comes from the factory with 3.73 rear end gears, so that's just over 11:1 total. First gear is certainly short, but it's not obnoxiously so.
