The GMW - E36 with a 5.3 and a CD009
Old Apr 11, 2022 | 06:56 PM
  #241
Michael Yount's Avatar
Glad you got it going. I’m liking the cable in mine more and more!
Old Apr 14, 2022 | 09:18 PM
  #242
one4torque's Avatar
M yount - did you go w a fox style cable clutch??
Old Apr 14, 2022 | 10:04 PM
  #243
No - Ford went with a Volvo-style clutch cable on the foxbody. 😉
OEM Volvo clutch cable pulling on the slightly longer SN95 clutch arm, Quicktime bell, McLeod aluminum flywheel, Hayes clutch, Ford throw out bearing, Tremec T5z all behind the LS3.
Old Apr 21, 2022 | 12:43 PM
  #244
TNspeed1's Avatar
Took the car for a drive last weekend and she rips. Here is a quick back out video.
Old Apr 21, 2022 | 01:18 PM
  #245
Daddy likes.....
Old May 31, 2022 | 10:21 AM
  #246
TNspeed1's Avatar
Quick update. The car is running pretty solid. I saw some higher temps than I liked when sitting in traffic so I drained the cooling system, pulled vacuum on it, and pulled new coolant in. Since then she has been perfect. Took her out for a Memorial Day cruise and the car is so much fun to drive. Hope to get a real alignment done this week.
Old May 31, 2022 | 10:28 AM
  #247
This thing HAS to be making Beemer purists overstuff their panties,,,,
Old May 31, 2022 | 10:34 AM
  #248
one4torque's Avatar
Default Added 3rd center hood vent
Just added center hood vent.
also just installed f body ac compressor. Fits e36 w frame rail massage.
upping my elec fan combo from 1600 cfm cap to 3300cfm w custom shroud… hoping to be able to idle in Hou heat w ac.
Your car looks fun!
Old May 31, 2022 | 11:09 AM
  #249
TNspeed1's Avatar
@G Atsma this car is like a Johnsonville sausage factory to those purists haha
@one4torque thanks man! I designed my louvers to be a little longer to allow for all that heat around the headers to escape (see below. Pay no attention to the terrible paint haha. That will eventually get addressed). After a 30 minutes of hard driving in almost 90 degree heat yesterday you could feel the heat pouring out of the vents. I put a IR temp gun on the louvers and there was almost a 40 degree delta between the louvers and the hood.
Old May 31, 2022 | 01:28 PM
  #250
LSswap's Avatar
Nice to see another BMW swap.
Old Jun 5, 2022 | 07:39 AM
  #251
TNspeed1's Avatar
Took the car out to Cars and Coffee this weekend. The weather was beautiful, there were a ton of cars, and the BMW ran amazing.
Here is a quick video getting on to the interstate.
Old Jun 5, 2022 | 06:18 PM
  #252
one4torque's Avatar
Sounds good!
I love my ls e36! Best car ever.
Old Jun 5, 2022 | 07:14 PM
  #253
TNspeed1's Avatar
They are fun! I smile every time I get behind the wheel.
Old Jul 13, 2022 | 12:33 PM
  #254
TNspeed1's Avatar
Quick update. The car has been running great. Still need to get a full alignment done and hope to have that wrapped up before the end of month. Also I got tired of sliding around in the factory seat. I found a good deal on a very lightly used Corbeau FX1 seat. Unfortunately all of the mounts I tried placed the seat to close to the dash. Being 6'-5" I had to make my own seat mount and now everything is mounted perfectly in the car.
Old Jul 13, 2022 | 12:38 PM
  #255
Reach out sometime if you wanna talk through aligning it yourself in the garage at home.
Old Jul 13, 2022 | 12:40 PM
  #256
TNspeed1's Avatar
@Michael Yount how the heck are you! I will definitely do that. I have it pretty close right now, but want a pro to dial it in. Also the same place will corner balance the car so I might be able to kill two birds with one stone.
Old Jul 13, 2022 | 01:01 PM
  #257
I was lucky enough to be able to borrow some corner scales -- so I was able to set the corner weights and do the alignment in the garage.
Old Jul 13, 2022 | 09:32 PM
  #258
dec010974's Avatar
Awesome
Old Jul 19, 2022 | 06:59 AM
  #259
one4torque's Avatar
I bought a home alignment kit off of Amazon. The ax guys use them due to going aggressive for track and dial back for street. Easy to use.
Old Sep 9, 2022 | 08:58 AM
  #260
TNspeed1's Avatar
@one4torque Which set did you get?
