The GMW - E36 with a 5.3 and a CD009
As summer approaches I want to make sure the car stays cool so I have been working on some radiator ducting. Yesterday I was able to get everything installed and bolted up. I am pretty happy with how it turned out. Please ignore the bug guts all over the front bumper hahaha.
I found out that I was bleeding my clutch wrong!
1- I run an f body separate clutch fluid reservoir.
2- us a turkey Baster to draw the old fluid out occasionally.
3- follow the well documented procedure:: m
push clutch pedal down…. Crack bleeder…. Close bleeder … let pedal up…. Repeat many times……. Also tap the clutch pedal down a couple mm’s over and over to release any air …. Believe it or not.. that last step seemed to firm it up.
4- put heat wrap in the clutch line .
5- put heat wrap on closest header tubes..
6- bleed the clutch ever couple thousand miles… that’s what I have to do.
gl
