LS1 T56 swapped C3 keeps dying ..
I swapped an 04 GTO LS1 T56 into my C3 corvette.. I bought my harness, headers and had the GTO PCM reflashed by street and performance. I started this odessy in 2015. Since that time Street and performance has gone out of business due to the owner passing away, So I finally got everything together. I got the beast running. It ran pretty sweet. So I hooked up the exhaust accesories etc. Everything functioned perfectly. After I added coolant it wouldn't run. It just loads up with fuel,and stumbles then dies. The first time it did this it appeared to be a bad 12v constant connection to the PCM. I reseated the connection and boom it ran. The next day it presented the same symptoms.. I have doubled checked grounds, re-ran the 12 volt PCM connection to a better source. I changed the coolant temp sensor. It ran and I drove it. The next day back to square one. If I unhook the maf it will run for a few seconds longer and then die.. I pulled a plug and they are soaked. Since my vendor is now longer amongst us tech support is tough. Any suggestions would be greatly appreciated..
If your injector rails have the vacuum controlled fuel regulator I would definitely verify that the regulator diaphram is not cracked. We had your problem on a ls1 engine swap using the truck manifold (plugs would gas foul in a few minutes). After chasing every gremlin imaginable, we unplugged the vacuum line from the regulator to the manifold - it had gas in it. When we cranked the car, gas was flowing out of the vacuum line.
