Grounds
https://www.chevrolet.com/content/da...d-17-tooth.pdf
However, if you look at the pinouts in the document, there are only 2 grounds listed (the ones going to the heads. There is a ground reference in the 12 cavity bulkhead connector, but generally that is not used.
Can you elaborate more on the kinds of problems that you are having? Is the engine itself properly grounded to the battery?
Andrew
Battery to engine.
Engine to chassis.
In the case of a body-on-frame vehicle, tie both the engine and the battery to the body and the frame.
You mentioned the battery being in the trunk. How long of a run is it to the starter? How thick of a cable did you use for the main positive and ground cables?
Are you sure that your ignition switch is in good working order?
I don't know what car you're working with, but on older cars I generally take the old coil wire and have that trigger a relay, which in turn powers the ECM. The coil wire is hot both in RUN and START.
Andrew
I would also second to make sure that you have everything connected to the correct power sources, being 12V constant, 12V switched, and 12V start.
I have a FIXD app and OBD connector but it apparently has to have the engine running to read codes.My current weekend plan is to check all voltages when trying to start the engine, cleaning all battery and ground connections and retightening, detaching and reattaching all sensor connections, and adding a ground strap from each head to the engine block. Let me know if there are other checks I can make or things to do.
Thanks again for the help to date!!
