Wiring and Standalone ECM/PCM
Keep the stock PCM and let somebody else tune out the right things. Not sure but you may have left behind the drive-by-wire throttle pedal. Learning how to tune things yourself is neither easy or fast and people have really messed up their engines striking out on their own. The learning curve is steep and can be extremely expensive.
Rick
So. The engine and transmission you got are awesome. We have a really good combination of Gen IV parts. LS3 heads, VVT but not AFM/DOD, best intake, good internals etc. The bad news is, the E78 ECM is a bit of a mystery to people. It uses torque management, similar to a Gen V. Is that the ECM you have? For $750 you can get a brand new harness. For around $450 you can have someone turn that harness into a 4 wire hookup. That is likely your best option. I'm trying to do it myself and honestly it is a lot of work following wiring diagrams and trying to work out exactly what needs to get hooked up and where.
600ish HP is a lot without a turbo. With a turbo, easy. Without, doable but it won't last long and will be a pig to drive. Decide if you are going to go turbo now. It impacts how you setup your fuel system, and what you do to the engine before you get it in your R10 (which should have the correct fuel tanks thankfully - do you know if your engine has TBI?)
As bombardier said, start reading. Keep reading. You need to absorb a lot of information before you get too far along.
Cheers!
Nobody makes a standalone for the 6L90, I've searched plenty and every possible option, came to a dead end.
combine the two 12v battery/alt wires with a 30a fuse on the ign side of the join and connect that to your 12v battery power from your stand alone harness
the HEI wire goes to your key-on power
and the purple goes to your starter wire in your harness if you have one, if not it goes ...well...to the starter
be sure and add a switch for the pin going to "key" power on the pcm from the power supply. might as well add a second serial port right from the get go if you're gonna be playing with pcm hammer
pin outs I got from the sloppy wiki page
remember all that pcm hammer/ls droid stuff is like raw, experimental software. it's gonna need lots of beta testing.
Sloppy mechanics , also known as denmah , has an almost foolproof 500 hp kit at turbosforless , formaly known as vsracing ,
