Dyno Results LS3 68 GTO Clone
Old 01-14-2019, 07:43 PM
fbrown540's Avatar
Default Dyno Results LS3 68 GTO Clone
I got my car dyno tuned a few months ago and decided to post the results here. The car build is over at Performance years but that site has turned into a bunch of haters. If it doesn't have a Pontiac engine they don't want to hear about it. I figure the results would be appreciated here.
The engine is a 2008 GM LS3 crate, 430HP, 2006 GTO MAF, Eledbrock LS swap headers (no longer made), Pypes 2-1/2 exhaust, x crossover, Dynomax 17749 Super Turbo Mufflers, no resonators. 4L70E with stock 2006 GTO torque converter (about 2400 RPM)
Some photos of the Car
Old 01-14-2019, 07:46 PM
Project GatTagO's Avatar
Received 1,429 Likes on 902 Posts
Thanks for posting here! I am andrewb70 on the Pontiac forum and you are right, all they want to talk about is the Pontiac engine...blah..blah...blah...
You did an amazing job with this car and you should be proud.
Here is the build:
http://forums.maxperformanceinc.com/...d.php?t=584076
I would love to hear what it sounds like with the Super Turbo mufflers!
Andrew
Old 01-14-2019, 08:49 PM
Received 3,066 Likes on 2,386 Posts
Man, THAT is one CLEAN Poncho! And the LS engine makes it RIGHT! And I love the color!
Old 01-16-2019, 04:47 AM
cypris09's Avatar
Dang that thing looks nice! I feel ya on the "it's not a Pontiac motor" thing. Even though they put them into the later gtos. Still hear " oh those weren't real gtos" oh well. Beautiful car man, if mine turns out half as nice i'll be happy.
Old 01-16-2019, 05:06 AM
AINT SKEERED's Avatar
Nice car and good job on the ls swap.
Old 01-16-2019, 07:40 AM
kirk1161's Avatar
10% drivetrain loss over crank HP, Outstanding! Nice car too BTW.
Old 01-16-2019, 01:17 PM
Zanie's Avatar
I did a first and last page scan of your build (during a short lunch break) Beautiful job on your car. Well done sir!
Old 01-16-2019, 07:22 PM
LS1 TJ's Avatar
Very nice. I'm a Pontiac guy but also a LS guy. It's a great combo the LS3 and the 4L70E. If you want a little bit more off the line a 3200 stall converter from Yank or Circle will not hurt anything on the cruising side.
Also a bit bigger cam like maybe 230I/235E would most likely bump the RWHP past 400-410 with no loss of driveability.
Again nice car.
Old 01-16-2019, 07:40 PM
I would have NO objection to owning a car like this one! So CLEAN!
Old 01-16-2019, 08:10 PM
fbrown540's Avatar
Thanks for all the kind comments.
One thing I forget to mention, the ECM is a E67 and not a E38 as you might expect for a corvette engine. I wanted cruise control and at the time, the E67 was the only solution. This did make thing harder since the engine never ran right until I got it dyno tuned.
I had a 3000 stall at first. Off the line was not good. Up in smoke or a slow start. The rpm would rise too rapidly and it would break the rear end loose. There didn't seem to be any middle ground. You can see what I mean in the second link below. Wheel spin at 32% throttle. If there is something I am missing I would like to know. I am about to start a LS3/4L70E into a 77 Cadillac. I still have the 3000 stall converter sitting around and while I would love to use it instead of buying a new converter, I don't want the same problem will stall I had in the GTO.
Both of these were with less than 20 miles of the engine. Not great sound quality, but can get the idea. At no point in either video did I exceed 32% throttle.
Avi Video 1
AVI Video 2 At about 1:25 into this video you can see the minivan start to pull ahead of me and I gave it some more gas and got bad wheel spin. (32% throttle, I was data logging)
Probably more like 20% drivetrain loss. GM under rated this engine. There have been quite a few magazines that had dynoed this engine and there was about a 20 HP spread between 489 and 511.
Old 01-16-2019, 10:19 PM
Tramminc's Avatar
How's the gas mileage?
Old 01-17-2019, 11:11 PM
fbrown540's Avatar
Don't really know. Only about 200 miles on it since it was tuned split between two tanks of gas. Before it was tuned, I managed to go 210 miles (mostly highway) on half a tank. That would make it about 21 MPG. I do know that half a tank on the gauge is really half a tank. I checked the calibration. It should get better mileage now, since before the car was running really rich before the tune.
Old 01-17-2019, 11:48 PM
WS6 #3392's Avatar
Love your ride dude! Very nice build!
Old 01-22-2019, 01:43 AM
KW Baraka's Avatar
He should be able to manage at least 24 mph cruising at a steady 70 MPH. I base this off the mileage I get with my cam'ed LS3 1995 Impala SS.
KW
PS: Yeah....me likes this considerably!!!
Old 01-22-2019, 04:06 AM
98CayenneT/A's Avatar
What tires are you running ?
Put a nice drag radial on there and it won't be a issue. Plenty of guys running bigger stalls without issue when running a radial.
I run a 4400 stall with a Hoosier Dr2 radial and spinning is a non issue. The Nt05r or Mt Et ss will also solve your problem.
Hoosier Dr2
Old 01-22-2019, 10:48 AM
Steve68's Avatar
nice ride!!!
Old 01-22-2019, 03:20 PM
CattleAc's Avatar
Man, this thing looks very bitchin'...
Old 01-22-2019, 05:59 PM
To say the least! Cool car, and the color is RIGHT!
Old 01-29-2019, 04:33 PM
fbrown540's Avatar
The color is alpine blue a 68 Pontiac color. The color is very rare. I don't remember seeing this color on any Pontiac back when these things were new.
KW
What engine mounts are you running in your 95 SS. I think I saw somewhere that you were running Hedman/BHP headers. But I didn't see anywhere where you stated which engine mounts you were running. I'm going to use KDS engine mounts in my 77 CoupeDeVille since they are reported to keep the factory drive line angle the same. I'm concerned about using the hedman headers since I understand BHP moves the engine forward and raises it.
Old 01-29-2019, 06:48 PM
They must have been saving that color for guys like us with exceptionally great taste....
