Cayman ls project begins
Even with a box stock LS3, this car is going to be lots of fun. 450ish HP & lb-ft in a 3000 lb mid-engine package that has all the rigidity, suspension and brakes to utilize it. Nuthin' but fun.
Stock its near 300HP.. Should hold up to similar abuse that the V8's get..
similar weight and what not to the Porsche motor for about 20K less..
I have built 2 one being a high-end car Porsche 914 , SBC and LS cars. I'm hoping to put all
the belt driven systems on the passenger side. Get a carbon type seat keeping it thin.
Here are my two gone but beloved 914"s.
SBC 930 4 speed with a Jetta PS rack and a Toyota MR2 electric pump and Ferrari 575 mufflers / with cutout valves
I did all the easy stuff on this one a very very skilled
guy did the incredible fabrication work.
How did the exhaust sound with the Ferrari mufflers? I am looking at doing 180 degree headers since I want the typical exotic Porsche sound out of the V8. I know it won't be exactly like the original sound at all, but I want something different and higher pitched with an exotic feel to it. I bought my motor mount kit from Stuttgart Muscle but I wouldn't hesitate to make a set. I just wanted to keep things easy for this swap and he has great prices, tech, and options for the LS swapped Porsche. I'm stoked to see your progress! The LS3 should kick *** with a good cam and tune.
Also speaking in relation to Porsche engines, which have NO low end power compared to LS's or most other V8 engines.
I DO see your point though.
And - just to further ventilate the point -- the Porsche engine in question is a 3.4L flat six that makes between 325 and 340HP in naturally aspirated trim. The reason that they don't make near as much torque or power as the V8's in question is because of the displacement difference. Some of that difference is because of the Porsche engine revving higher and some is because it's in a higher state of tune than the LS's in question. To me the comparable GM motor would be one of the 5.3's that makes around 325HP in factory trim. It makes it 1500--2000 rpm lower than the Porsche engine does. 275 torque and 325HP out of 3.4L without a booster is damned respectable. But it ain't gonna compete with a 6.2L (almost twice the displacement) at 430/424....unless you build the little 6 to still be breathing up around 8500-9000 rpm. And we're back to air-pump basic math.
Remember also that higher rev's beyond about 7500rpm really must have a dry sump oiling system... you should also have Ti valves in the heads.... need an intake manifold that can actually support over 7000rpm's..... plus engines just wear out quicker with stupid high revs.
Unless you have to fit into a racing class... run the big cubes. The stress from 1/8 and 1/4 mile racing doesn't really compare to 20-30 minute road racing punishment especially with heat management. HPR is doing big stroke.... LS motors that are pretty reasonably priced.
https://horsepower-research.com/prod...uminum-442-ls3 Personally I don't really want a motor over 4" stroke due to piston sideloading.... but I'm guessing Eric Koenig (HPR main guy) knows otherwise from lots of experience building LS engines for 15+ years and teaching at SAM. They probably refresh these motors every year.... but probably worth a phone call to them!
It all is in the "basic" knowledge category. speaking off the cuff and not under oath for sure
I'm still waiting for parts !!
I'm still interested in hearing how you liked the Ferrari exhaust on your last P car! controlled tips. Look like an LS3 is going to be my choice.
As mentioned before -- rpm sounds fantastic, but lord is it expensive.
