Over heating
The header tank is now an overflow tank, with the overflow hose from the radiator going into the bottom of it.
No difference that I can see. Temps still go up and up with the ac on
Martin
but the radiator is showing 150-170*F or less
It means water pump is not pushing water into engine(and out of engine afterwards). It must be recycling at the thermostat. This symptom is caused by running the LS engine without a thermostat (or having one that does not seal)
There are two kinds of thermostat I've seen that they sell for 5.3L engines. If you use the wrong design the above will happen.
I guess I've only seen the one thermostat, the one that is attached to the lower radiator hose neck at the pump and not just a t/stat on its own.,.....
Martin
My front steam ports go to the upper rad hose
I am actually looking at the water pump as we speak!
The Taurus fan is behind the radiator, pulling air. Has the shroud also.
I'm going to see what truck pulley pumps I have available that will fit, and look into swapping out the PRW POS pump
Martin
I need the front facing output with the LS6 intake I have installed for hood clearance, but have the truck accessory drive.
So if I get the spacers, I can run an off the shelf water pump, instead of this PRW one.
Suggestions for pumps? From my reading I need the 3/4" spacers?
Martin
Going to get rid of the POS PRW water pump and get a LS1 one, with the 3/4" spacers. The spacers have the hookup for the steam line, so will just run a hose from the pump to the radiator.
A restrictor may be needed on the thermostat side, so the coolant stays in the rad longer. Griffin suggested that after sending them some readings
[/QUOTE]
Dang. Just caught that. Thought they were a reputable company. Maybe you misinterpreted? Maybe they were talking about blocking the thermostat bypass?
Do yourself a favor and delete any posts mentioning steam vents. The amount of bandwidth wasted talking about those silly things has to be astronomical.
Not sure what your problem is, probably the WP like you think, but whatever you do fill that great big gaping hole in the top of your fan shroud so it pulls air through the radiator and not through that gap.
Thank guys
Just got back home yesterday
I installed the Corvette water pump and spacers.
Same result
I can pressurize the cooling system with no leaks, so HG is doubtful, not to mention newish motor.
I've second guessed the water pump rotation myself a hundred times. But every time I look it looks right.Right now its reverse rotation, but here is a picture of the belt. Please let it be that simple! I wish....
Thanks again guys
Martin
I would recommend the freeze plug trick just to test that you are getting coolant flow through the block
use a rubber freeze plug to block off the water pump bypass hole
https://www.yellowbullet.com/forum/s...d.php?t=621363
With the bypass blocked, coolant forced into the block with no regard for thermostat. Then you can tell if the fans/radiator are doing their job by temp gauge/heat gun.
I am referring to the bypass hole inside the pump under the thermostat
All in all you should be adding 3x plugs, 2 for the heater and 1 to replace the thermostat
Not saying that’s your problem. This entire thing just seems like air in system somehow.
