LS3 Into 2003 Z71 Tahoe
Need some help here fellas. I just picked up an LS3 with PRC cathedral heads. Going to transplant it into a 2003 Z71 Tahoe. Plan on using my intake. Reading many forums I'm seeing answers and links all over the spectrum. Does anyone know exactly what all is needed to perform this swap?
Thanks in advance.
Thanks in advance.
The lingenfelter box is for the crank sensor.
you will need to extend the cam sensor harness (and flip the outside wires) since the ls3 places the cam sensor on the front cover vs the older which has the cam sensor at the back of the block.
The cam sensor only tells the ECM whether it's on intake or power stroke so the spark is on the right stroke. It eventually figures this out without the cam sensor, but starts much faster with it.
