5.3 What car to put it in?
Old Feb 4, 2020 | 01:51 PM
RoastBoost's Avatar
Default 5.3 What car to put it in?
I have a 5.3l truck motor i want to drop into a car and turbo. My question what is the best bang for my buck when it comes to cars to put it in. I’d like to put it in a older Supra or RX7 but is there advantages to doing a S10 or foxbody instead? I guess if the motor is the same is any chassis superior platform to go faster easier or cheaper?
Old Feb 4, 2020 | 02:14 PM
Tuskyz28's Avatar
Supras are rare and cool but parts are expensive. Probably best for handling...
Foxbodies probably out pf the cars you listed is probably best for drag racing. Parts can be cheap but expensive. I just hate going to the track and thats all you see...
Rx7- cool car thats kinda overlooked...
S10- cheap but making one hookup at the strip could be very tricky and expensive.
I had a 79 LUV truck... 400 horse estimated and i never got traction. Death trap or i say a casket on wheels.
Old Feb 4, 2020 | 02:25 PM
LLLosingit's Avatar
There are quite a few running S10's with nothing more than mono's and Caltracs or Assassin and hooking hard with minimal work, To get them to hook on the street you need to put it on a diet and put as much weight in the bed as possible and that's not always practical.
People also assume since it's a small truck that they are light, They still have a heavy full length steel frame and weight wise are about the same as a 90's Camaro. My S10 is actually a pig but it's an extended cab with an Iron 6.0 with LSA supercharger and still has A/C... It's almost 3,800lbs.
I do agree that the Fox Body is the way to go unless you can do your own fab work.
Old Feb 4, 2020 | 03:46 PM
RoastBoost's Avatar
What about a G body or a 240sx
Old Feb 4, 2020 | 07:28 PM
LLLosingit's Avatar
G-body will drop right in but it's not a light car and the swap parts are reasonably priced, They sell swap kits for the RX7 and they are light but I believe the rear end is the weak link. What do you plan on doing with the car, Street or drag or both?
Old Feb 5, 2020 | 08:31 AM
RoastBoost's Avatar
it’s just gonna be a street car it may see the track once or twice but primarily a street/fun car
Old Feb 5, 2020 | 08:43 AM
RoastBoost's Avatar
What about F Bodies? I can find most of these cars for around $1000-1200
Old Feb 5, 2020 | 10:53 AM
LLLosingit's Avatar
If it's just going to be a street car pick the one that you like and don't worry about weight, You'll have more power than you'll be able to use anyway.
Old Feb 6, 2020 | 12:01 PM
kott0n's Avatar
I've had this same dillema. I've had the LM4 5.3l for 2 years, still in the donor vehicle. I'm slowly amassing all the hard parts. 4l80e, Jakes rebuild kit, slip yoke, flywheel, new rear main, hptuners as I have other vehicles I can use it on, NGK wideband,
I still need: pac 1218, ls7 lifters, trans cooler and a car style intake to clear a hood on most vehicles.
Ive put a ton of time into a what to use for the swap vehicle and the best dollar per performance is hands down a Mustang.
So much aftermarket support for suspension, its unreal. They are also getting reproduction part love from the classic auto group for the interior/exterior items.
I personally will be using an Edge Mustang as they were the hotness when I was highschool. I personally think year for year the Mustang has looked better than F-body, despite me owning F-body's.
Old Feb 25, 2020 | 12:00 PM
Old dog new tricks's Avatar
My son and I are doing this currently so far just change the oil pan to LS1 with a couple mods to the windage tray to make the pickup tube fit use the LS1 stock motor mounts on the 5 3 it bolt right in we're also using an LS1 intake with slight modifications to the alternator bracket and relocating The idler pulley
Old Feb 25, 2020 | 12:02 PM
My son and I are doing this currently so far just change the oil pan to LS1 with a couple mods to the windage tray to make the pickup tube fit use the LS1 stock motor mounts on the 5 3 it bolt right in we're also using an LS1 intake with slight modifications to the alternator bracket and relocating The idler pulley .5.3 into 02 v6 Camaro
Old Feb 25, 2020 | 12:14 PM
cookseyb's Avatar
The intake problem goes away with a LS1 water pump and ICT billet 3/4 inch spacers..
Old Feb 25, 2020 | 03:39 PM
LS BRAVADA's Avatar
Mazda Miata
BMW 3 series
GMC Canyon
Old Feb 25, 2020 | 05:45 PM
LLLosingit's Avatar
Originally Posted by LS BRAVADA
GMC Canyon
You'll be around 4,000lbs with that truck. They aren't light and don't handle well without spending quite a bit on upgrades.
Old Feb 25, 2020 | 07:13 PM
huggerls1's Avatar
I put mine into a 72 el camino i got a decent deal on.
Old Feb 26, 2020 | 06:30 AM
Michael Yount's Avatar
A little "different" approach....a number of folks out there in the 9's with JY turbo motors.
http://www.volvojo.com/2017/03/21/60...-vs-the-world/
