~85 psi at the Fuel Rail??
I went through and checked the basics, plugs, wires, coils, cam sensor, crank sensor, and still the same issue. So just to humor myself I decided to check my fuel pressure, and something is obviously jacked up. When I turn the key you can hear the pump turn on and prime, and when it does this the fuel pressure gauge (measured at the rail) charges to ~80 psi then settles quickly back to around ~50 psi and then stays there. However, once I crank it over and it starts up the fuel pressure immediately jumps back to ~85 psi and stays there. Turn the car off and the fuel pressure drops back to ~50 psi. It doesn't stay at 50 psi though. It drops at about ~1psi a min. I waited ~45 mins and when I returned it was ~ 10 psi at the rail.
I have a walbro in tank fuel pump, plumbed to a corvette style fuel filter/regulator, to the stock ls1 fuel rail. My initial guess from everything I have researched would be that the regulator is shot? Its brand new at least it was at the time of install (less than a year ago), also if it failed I would expect to see low fuel pressure not high. Also the fuel pressure dropping has to either be injectors leaking by or the check valve in the pump is dead. If the check valve in the pump is the problem i assume i can add an inline check valve to remedy that problem, but that wouldn't help the crazy high fuel pressure. Any thoughts or ideas? Any help would be greatly appreciated, been fighting this for about a month now, and I finally think I'm on the right direction.....hopefully.
Ya this is my guess as well, just wanting to get some other insights/opinions.
So, the easiest way I have found to test a regulator is to remove it from the system and drain out any fuel. Then using a standard air compressor, apply 125 pisi of air the the inlet port, monitored with an air gage. The gage will read the regulated pressure. If the ball/disk leaks, the readings will be less than the set pressure. If the gage reads much higher, like 85 psi, in this case, then the regulator ball/disk is either sticking closed or the return portion of the system is restricted.
I do realize there are flow dynamics that are different between fuel and air but this is a safe, quick and easy way of testing the regulator. Remember you have mechanical issue that is showing its effects as a significant pressure increase. So dont guess, think, wonder or throw money at the issue. Test, measure and eval you results.
Just my thoughts and process.
Great write up, thank you for taking the time to post. I am following and completely agree with your opinion.
That being said when I got home today (and before I read this) I pulled the rail with the injectors still attached and primed the system to verify that none of the injectors were leaking by. Good news is, none of them were.
However, I still am loosing about a ~psi a minute of pressure. That being said that loss can only come from one place since it’s not coming from the rail, lines, or injectors.
The pump check valve. What I’m curious about though is, is that rate of pressure loss normal? Or should it hold pressure after the pump shuts off for longer than a 1 psi a min drop (I.e. in an hour the gauge is reading close to 0 psi). If that drop in pressure of about 1psi a min is normal, then I agree (and now can test) that the only issue is the FPR. If that drop in pressure is not normal then I suspect the check valve in the pump is bad, AND the FPR is bad (causing the 85psi when idle).
That being said, anyone out there run a corvette style FPR with a pump that flows more than 255LPH? If so do you experience any issues killing this style FPR? Like I stated in an earlier post some sites that sell it state its not recommended with use of a pump that flows > 255LPH. I don't want to keep having to replace this FPR, so im trying to decide while its dead do I go with the corvette FPR that just failed or replace it with an adjustable Aeromotive one and dial it in to 58 psi.
On the flip side, testing by Lngenfelter showed that the fuel filter becomes a restriction at 270 lph (same as f body). What that means is the rail pressure will go below set point when your engine demands more than that. Basically you've got a tuning nightmare on your hands with both high and low pressure swings. The high pressure swings are the much harder part to deal with because it won't be consistent enough to tune around.
That being said I had this car tuned ~3 months ago, and paid $700 for the tune work, and it showed to maintain a nice AFR the entire time. I am wondering though if we just got lucky that day or what. My fear is that now that I know the fuel pressure is a problem, once I fix it, I may be running super lean. Thats assuming at the time of the tune the tuner was leaning out the mixture to get a good AFR (but not knowing my fuel pressure was at 80PSI). I dont know if it is that impactful since the tune to my understanding is based on the injector pulses/control/flow rate, and I dont know how much the ~22psi difference would make. If I get it back to 58 PSI in theory I should still "get" the same amount of fuel, but if I dont I likely will need to get it re-tuned which really pisses me off haha.
I have HPtuners and actually did this the other day. It confirmed what we all assumed it’s the FPR that has failed causing the high fuel rail pressure. Plan is to replace it with an Aeromotive 13109, and re-plumb the system to eliminate the corvette FPR all together. Then dial it in to ~58psi, and be good to go!
Bad news is, car still has the intermittent hard start issue. This is really starting to wear.
Problem remains the same after replacing/swapping the FPR, crank sensor, cam sensor, plugs, wires, and coils.
My only thought i keep coming back to is my injectors. I have done the test to verify they are not leaking, and I can here the “click click” when the car is running on all of them, but I just don’t know what else could cause this intermittent hard start, I really thought finding the pressure so out of whack was it, but even with it perfect it still does it.
The engine sat for many years in my garage before it was swapped in, that’s the only thing that makes me think even though I haven’t been able to catch it or prove it that maybe something is going on with the injectors causing the intermittent hard starts. Because I have fuel pressure and spark. I don’t know....any input or help is greatly appreciated.
you really think that will solve the hard start? Just a tuning issue now....because the hard start was doing the exact same thing before and after the tune.
Are you confident you are getting good voltage for the ECM during cranking? Perhaps the way you are wired and grounded is occasionally not giving enough juice for the ECM to fire the injectors and coils during high amp crank draw.
