Radiator Fan for stock LQ4
! have a 53 Chevy 210 I put an LQ4 in. I have only 3 inches between the radiator and water pump. I was looking at this Spal but was wondering if it's going to move enough air. I was looking to see if anyone had any experience with these. The shroud I am going to get is 3/4" thick
16" Spal 2" thick
I might be able to fit this one if I move the radiator forward a bit.
16" Spal 2.4" thick
16" Spal 2" thick
16" Spal 2.4" thick
I use the SPAL twin 11” shrouded fans on a stock LS3. One benefit of the twins is you don’t have a fan motor right in the center where the water pump pulley is.
Click on the fan you’re interested in and there’s tech info including flow. https://www.spalusa.com/products/fans/16/
That unit is 24x16 - should go on your rad with no problems if the depth will work. I don't think the bit of non-shrouded radiator will pose a problem.
Attachment 712742
If you look closely between the air intake tube and the upper radiator hose you'll see the tip of the water pump pulley. I went with Corvette pulley spacing to give myself even more clearance to the rad/fans. That swap would give you over an inch more clearance - but, not inexpensive to pull everything off and start over. Previous engine for me was a 5.0L Ford and I literally had about a credit card thickness of clearance between the back of the fan motors (same fan unit - now 17 years old!) and the a/c compressor pulley. Got tired of that and gave myself every bit of clearance I could find when I swapped in the LS3 about 4 years ago.
Attachment 712800
Attachment 713890
Attachment 712742
Attachment 712800
Attachment 713890
The following users liked this post:
postalcop (05-28-2020)
FWIW - this fan set up has performed flawlessly with a Delta Current Control variable speed controller for almost 20 years. Car runs right at 197F when t’stat is controlling and right at 203F when fans are controlling. With A/C on or not. Works as well as the OEM set ups in our newer daily drivers.
