5.3 coolant / over heating
Thanks !
I have the 1/4" line that comes off the steam port, going through the TB connections then directly to the 1/4" nipple on the radiator by the cap. Is that correct? Or does that 1/4" need to go to an overflow tank?
Andrew
sounds like that's my issue then. I'll return the steam port back into the radiator hose.
Thanks for the help! This has been a hell of a learning curve.
The coolant in the system expands and contracts with temperature. You either leave it low in the radiator tank, or it's gonna expand and push out of the cap/vent and end up everywhere. Overflow tank preferred. Even better a pressurized reservoir with steam ports plumbed into the air space at the top of the reservoir....
can I come out of the pass side steam port ( yes, pass side and drivers side are connected) and go right to the upper coolant hose?
You can actually drill and tap the side of the water pump and just run the steam line back into the water pump.
If you have the heater hose ports on the water pump blocked off, I also recommend drilling a small hole in the thermostat or right next to the thermostat. This keeps a small amount of water circulating by the thermostat and it will open and close more consistently.
My car runs at 195 with the stock t stat and never moves.
Also, how you bleed the system of air will really help with air bubbles. I tend to fill it with the front of the car jack up in the air. I’ll leave the steam ports lose and fill it till all the air is gone and have only coolant coming out of the steam ports. Then tighten them down and top it off the rest of the way.
I didn't drill the t stat ( don't know what size hole or where to drill) it's a new T stat.
do I have it plumbed wrong? The lower rad hose goes to the T stat, the upper rad hose goes to the other port on the water pump.
The other issue is my fan isn't coming on. PCMofNC setup the ECU to turn on the fan.
to me it seems like the t stat isn't opening, circulating the fluid. How the hell do I get the t stat to open !
What I usually do is fill the system and start the engine and pull the steam line loose (near the engine) until I get a steady stream out of it and then put it back on.
this coolant issue is the last thing stopping me from getting this '53 Cadillac back on the road where it belongs...
